It is currently Tue Jun 16, 2026 1:52 am
 Post subject: New Ks Luv owner
PostPosted: Sun Oct 21, 2012 10:22 pm
Im Laine. I picked up my first Luv, its and 80. My brother 77 luver has been harping on me for awhile to get one. I bought my 80 with it partially dis assembled. So far my progress is slow and alil disheartening.
 Post subject: Re: New Ks Luv owner
PostPosted: Mon Oct 22, 2012 12:00 am
sounds like my luv when i first got it :lol: took me a good few months to get it running and another few to get it running right
do you have any pics of it yet?
PostPosted: Mon Oct 22, 2012 12:05 am
Here it is....haven't driven it yet so no name for it yet
PostPosted: Mon Oct 22, 2012 12:09 am
its a place to start, i have had mine 2+ years and still no name so your not too far behind :lol:
is it a runner as it is or are you going to do some tearing down and a rebuild along with the assembly
PostPosted: Mon Oct 22, 2012 12:24 am
With a little assembly and the pump relay jumped she fired up. But im having trouble with the carb after we rebuilt it. But im going to swap to a Weber and header. It came with a 3inch body lift to put on but no instructions..... But I have to replace the cab floor at all four mounts before that. I got two beds and a third first gen bed on a luv frame trailer. So a few things on my list
PostPosted: Fri Nov 02, 2012 12:45 am
Also...I've read on here that the fuel pump relay is powered by the voltage regulator. If my trick does everything but power the starter thru the relay fine does it still mean the vr is bad?
