It is currently Tue Mar 17, 2026 8:44 pm
Post new topic Reply to topic  [ 1122 posts ]  Go to page Previous  1 ... 44, 45, 46, 47, 48, 49, 50 ... 57  Next
 Post subject: Re: LUV II
PostPosted: Mon Sep 17, 2012 7:59 pm
I run his First set of hubs, no problems at all. I did drop ship new rotors to him. They stop my V-8luv without any issues.
PostPosted: Thu Sep 20, 2012 10:20 pm
LSX LUV Owner
My dad will be able to get back on the hubs here soon. Get them knocked out and to Raland then go from there on pricing.
Been driving the luv daily the past few days because the weather has been awesome. No problems whatsoever *knocks on wood*. Guys at school thought it was perfect for break time.
PostPosted: Fri Sep 21, 2012 4:51 pm
Been great weather lately . Looks like you are getting to enjoy it a little .
PostPosted: Mon Oct 01, 2012 7:15 pm
LSX LUV Owner
PostPosted: Mon Oct 01, 2012 7:43 pm
Beautiful! Any pics of how you put the front end on?
Rick
Loranger, La
1980 Stepside LUV (Again)
PostPosted: Mon Oct 01, 2012 8:01 pm
LSX LUV Owner
Put the inner fender/core support on. Bolt on fenders and everything else. I took it off in one piece once and it was a major hassle. I completely disassembled the front end in 30 minutes by myself.
PostPosted: Tue Oct 02, 2012 7:53 am
This truck is so badass ive looked through your thread so many times for ideas great work you've done. Keep it up, oh yeah what are you doing to it now?
PostPosted: Fri Oct 05, 2012 8:14 pm
LSX LUV Owner
Got the new to me inner fender/core support. Need to do some tweaking to make it fit
PostPosted: Sun Oct 07, 2012 3:41 pm
LSX LUV Owner
did a little trimming on the inner fenders to get it to fit.
PostPosted: Sun Oct 07, 2012 7:59 pm
You have this way of making everything look easy. 8)
PostPosted: Sun Oct 07, 2012 8:14 pm
+1. Amazing work.
PostPosted: Mon Oct 08, 2012 9:46 pm
That is the perfect size radiator .
PostPosted: Thu Oct 11, 2012 7:17 pm
LSX LUV Owner
Yes it fits with 1/8" of clearance on each side
Lower radiator mount.
PostPosted: Sat Oct 13, 2012 2:53 pm
LSX LUV Owner
Got a little more done today. Need to fill some spots on the core support, then cut a few strips of sheetmetal to overlap the joint where the inners meet up by the firewall. The new clip's cuts were not straight like mine so i need something to hide that. Drilled out the spot welds for the battery indention and whipped up a filler piece for it.
PostPosted: Sun Oct 14, 2012 12:19 pm
I see A/C in the back ground . Thanks again
PostPosted: Sun Oct 14, 2012 6:31 pm
LSX LUV Owner
Yeah i got it from a dads friend of mine. Isnt going to work like i wanted it to. And no problem.
PostPosted: Sat Oct 20, 2012 12:53 pm
LSX LUV Owner
Took the clip to my dads work earlier and got the majority of it sandblasted. The cabinet was only 2" wider then the clip so I had a hell of a time getting to some of the spots as is. SO after two hours of blasting I called it quits. A couple spots have some paint left, but it can be hit with a wire wheel.
PostPosted: Sat Oct 20, 2012 1:57 pm
Nice work 8)
PostPosted: Tue Oct 23, 2012 11:08 am
LSX LUV Owner
Thanks. I'm itching to get it back together. Haven't drove it in a while. Weather is getting better so it will be enjoyable to drive. Me and my dad have had a few cars we have been working on for a co worker and the co workers brother. So i haven't had a whole lot of time to get the rest of it welded up.
PostPosted: Sat Oct 27, 2012 1:34 pm
LSX LUV Owner
Getting closer, I have everything welded up and ground down except the two strips by the firewall. Putting everything back together now to make sure everything is fitting like it should. Need to hole saw a couple holes for wiring, and make a bracket for horns to bolt to. After that gonna put a little filler on a few areas to smooth it out, and then bedline it.
