It is currently Mon May 25, 2026 10:03 am
 Post subject: Direct Ignition System ?
PostPosted: Thu Sep 27, 2012 10:48 pm
Cant seem to find something like this for a Chevy V8.
i know the newer cars and truck run. it stock. my ? is can i take it off a newer chevy moter and put it on a old 1970s V8?
PostPosted: Fri Sep 28, 2012 7:56 am
by irect ignnition are you talking about the coil on plug setups with crank position sensors and such?
i would think it COULD be done using something like a ford edis setup to run it and a megajolt ignition only computer like ctmandu put on his stepside with the yamaha r1 carbs. megasquirt and megajolt are some advanced systems for how cheap they are.
www.diyautotune.com has most of their stuff
PostPosted: Fri Sep 28, 2012 9:06 am
It seems like I read something about one of these setups on this board. I did a search and came up with nothing though...
PostPosted: Sat Sep 29, 2012 1:01 am
check this tech article out
they take a 350 from carb to tbi, to mpfi step by step and parts list
http://www.diyautotune.com/tech_article ... 1-nova.htm
PostPosted: Sun Sep 30, 2012 9:22 pm
http://www.diyautotune.com has most of their stuff
yep like ctmandus truck. but for a v8 setup. if i put a 350 in my luv id like to get the heads about 1" away from the fire wall. so no distributor setup. i liked how my V8 luv was. the front two pistons where all most over the spindles. but with my old luv i dont what to cut up the fire wall.
V8
old LUV
PostPosted: Sun Sep 30, 2012 9:58 pm
then yeah your gonna want an edis8 wheel and sensor setup and a megajolt or megasquirt 1 ignition only. cat had megajolt and edis4. they are really good for tuning ignition and you can mess with your timing whenever you see fit by plugging it in :lol:
PostPosted: Mon Oct 01, 2012 9:33 pm
They have crank fire ignition systems.Look at Jeg's,Summit or any other parts catalog. They also Have DIS setups for sale too.
Users browsing this forum: Bing [Bot] and 24 guests
