It is currently Wed Jul 01, 2026 7:49 pm
PostPosted: Fri Sep 21, 2012 7:05 am
I need to replace the ORIGNAL turn signal/ dimmer switch combo on my 1979 base model LUV... All the auto stores say it is a floor mount switch but mine is on the column... Is there any web site that has the original (correct original) equipment? 1979 1.8 L / 3 speed auto
... Good, you've located the problem; step 2 is washing it off.
PostPosted: Fri Sep 21, 2012 7:33 am
Have you checked rockauto.com?
PostPosted: Fri Sep 21, 2012 8:16 am
nevermind. I just looked now that I've gotten home, all floor mounted.
PostPosted: Fri Sep 21, 2012 8:23 am
Then is mine a one off oddball? I always end up with those. Or is that just some generic "replacement"... What does yours have? Floor mount dimmer or column?
PostPosted: Fri Sep 21, 2012 8:46 am
No,yours is not an oddball.
The 79 dimmer switch is in the turn signal assembly.
I could be wrong but I believe all of the LUVs had them located there.
PostPosted: Fri Sep 21, 2012 9:48 am
Let me know where I can find a replacement if anyone has the info... Thanks! :eugeek
PostPosted: Fri Sep 21, 2012 1:21 pm
your best bet will be at a junkyard or on this site. I doubt you'll find a new one anywhere.
what's wrong with yours? broken or just not working?
PostPosted: Fri Sep 21, 2012 1:39 pm
Just old... Dimmer switch starting to short and I have to disengage the right turn signal by hand.
Users browsing this forum: Bing [Bot] and 56 guests
