It is currently Wed Jul 01, 2026 3:34 pm
 Post subject: different situation
PostPosted: Sat Sep 08, 2012 8:19 pm
When the voltage regulator is connected i don't have power in the carburetor (shock and low speed),
When voltage reguklator is disconected i have power in the carburetor and the car runs for few seconds, I replaced the Voltage regulator, alternator, new ignition switch and doesn't help.. :(
another thing I notioced the gas pump is running all time never shut off either if the gas level is above the "level dot" in the small glass located in the carburetor (with the VR disconected)
I clean all the fuse box and also rebuild the carburator and replaced the filter.
could be the electric points?
the exhaust manifold has a small crack could be the reason?
relay?
coil?
capacitor?
Please help
 Post subject: Re: different situation
PostPosted: Sun Sep 09, 2012 2:00 pm
Relay would be my guess
PostPosted: Mon Sep 10, 2012 5:49 pm
Could be a fuel problem. Either too much (carb float) or not enough (fuel filter/pump).
PostPosted: Tue Sep 18, 2012 8:43 pm
I disconected the wire (black yellow o white stripe) and theb relya and the low in the carburetor have power!!
coul be bad selonoid in the starter?
Users browsing this forum: Google [Bot] and 35 guests
