It is currently Tue May 12, 2026 12:22 pm
PostPosted: Sat Sep 08, 2012 6:17 pm
Ok so bought a luv and it runs great other than this problem...its a automatic and ill start it(starts fine) put it in reverse and then drive but as soon as i give it gas it dies??? But if i let it warm up for 15 mins it wont do it....and when it is having this proble it will die every stop sign until about 15-20 mins into the drive...any info would be greatly apprieciated!!!! Would like to make it my daily driver so i can bag my s10!!!!
PostPosted: Mon Sep 10, 2012 5:51 pm
Sounds like a carb problem to me.
PostPosted: Mon Sep 10, 2012 5:58 pm
Carb and also check the points
PostPosted: Mon Sep 10, 2012 8:56 pm
Choke on the carb or plugged idle circuit.
PostPosted: Tue Sep 11, 2012 8:48 pm
K ill check as soon as i can...works got me working alot....so if it was carb would a simple cleaning work mayb or a whole disassemble???but thanks for the ideas!!! Keep em coming and ill try some this weekend :ebiggrin
PostPosted: Sun Sep 16, 2012 8:00 pm
Heard it could be a coolant temp sensor?? What u guys think??
PostPosted: Sun Sep 16, 2012 8:22 pm
The sender would have nothing to do with your problem.
PostPosted: Thu Sep 20, 2012 3:18 pm
Found out what the problem was.....accelerator pump was crap....thanks for the ideas guys :ebiggrin
