It is currently Tue May 26, 2026 3:26 am
PostPosted: Tue Sep 04, 2012 7:14 pm
what did any1 use for body mounts, or where can u find them, and can any1 help with doing 1 peice windows
PostPosted: Tue Sep 04, 2012 8:27 pm
If you mean the door windows, just replace them with newer doors that don't have wing windows.
PostPosted: Tue Sep 04, 2012 10:24 pm
ok, what year do not have the wing window? or is there anny other truck i can use the track off of?
PostPosted: Tue Sep 04, 2012 10:33 pm
PostPosted: Wed Sep 05, 2012 8:22 pm
what about body mounts? where can i find new ones?
PostPosted: Wed Sep 05, 2012 11:05 pm
You won't. On various vehicles over the years, hockey puck was cut down and used as a substitute, if you are so inclined. I have machined them out of various plastics as well, but you need a mill and/or a lathe for that...
PostPosted: Thu Sep 06, 2012 8:21 pm
ok thanks. ill find something to use
PostPosted: Sat Sep 22, 2012 8:58 pm
could use toyota bushings from an early model thir bout the same
Epic Fabrication.
KAOS
