It is currently Mon May 25, 2026 11:47 am
Post new topic Reply to topic  [ 29 posts ]  Go to page 1, 2  Next
 Post subject: pup to luv disc brakes
PostPosted: Wed Aug 29, 2012 8:38 pm
can any1 help me. i have the backing plate. the pup hub and the pup rotor. idk if the rotor is wrong or what but is there supposed to be a huge gap between the hub and rotor where that all bolts together? or should it be flush??
PostPosted: Wed Aug 29, 2012 10:12 pm
Are you trying to keep the luv spindle and just swap over the backing plate and disc brake components? I used '81 luv (same as pup) brake components on my '75 but I swapped the entire spindle with all components on it.
It worked but the arm for the tie rod is located a little bit different so I had to adjust the toe out a bunch to get it back into alignment.
Good luck,
Eric Q.
My build thread.
PostPosted: Thu Aug 30, 2012 3:18 am
Australian LUV Guru
The Pup brake rotor should bolt up flush to the hub, they are a tight fit so tighten the bolts in a cross pattern to pull the hub and rotor together.
1980 4x4 KBD40 ISUZU/Chev Luv
PostPosted: Thu Aug 30, 2012 7:01 am
He never told us what year his LUV is, or what year the P'up are from. Isuzu made changes in '84, and some components are not interchangeable. Wonder if that's part of the problem...
PostPosted: Thu Aug 30, 2012 4:51 pm
Luv is a 73. I have the spindle and backing plate off a 85 pup, the rotor off a 85 pup, I jut got my caliper also for an 85 pup. But the rotor doesn't go close to the hub off an 85 pup. there is like a 2-3 in gap??? if I knew how to post pics here I would do so
PostPosted: Thu Aug 30, 2012 8:38 pm
When you're composing a reply, look below the "Submit" button. That whole section is for adding attachments (photos).
PostPosted: Thu Aug 30, 2012 10:13 pm
ok ill try and post what im talking about in the am when i can get better pics
PostPosted: Fri Aug 31, 2012 8:47 am
ok one of the shops in town i went and talked to and showed him whats going one, he use to drag race the luvs, "hookers automotive"... he informed me i do have the wrong rotor.
PostPosted: Fri Sep 07, 2012 10:56 pm
im not able to post pics for some reason. but i need help? i think i have wrong parts again....
PostPosted: Sat Sep 08, 2012 6:45 am
Are the pics on your computer? When replying (that is, after you click Image), look for the "Choose file" button in the "Upload attachment" section (scroll down, there's more below what's on your screen).
PostPosted: Sat Sep 08, 2012 11:30 am
it keeps telling me my file is invalid??
PostPosted: Sat Sep 08, 2012 1:51 pm
Well, apparently you're on the right track. What KIND of file are you trying to upload? Is it a .jpg, .bmp, .gif, or what?
PostPosted: Sun Sep 09, 2012 12:33 pm
im not sure..
PostPosted: Sun Sep 09, 2012 1:48 pm
luvkid73 wrote:
im not sure..
Since you don't know, and I definitely don't know...the error message seems to indicate you're trying to upload a file type that is not supported. The .jpg and .gif file types are generally usable on forums, but anything else may not work, depending on what the forum operator allows. On my site, I don't allow .bmp uploads, because they take way too much space.
PostPosted: Sun Sep 09, 2012 9:35 pm
yea idk anything about the pic files. but my problem with the truck is. my caliper doesnt bolt to the spindle like it should. one bolt is about an inch off, everything is for the 88 spindle i have. and with the caliper bracket there isnt much room for pads its almost a tight fit over the rotor without the pads.. wish i can figure out y i cant post the pics to show every1
PostPosted: Sun Sep 09, 2012 9:43 pm
You have posted that you have 85 model parts, and 88 model parts. Could be part of the problem...
PostPosted: Sun Sep 09, 2012 10:36 pm
I the problem with the brakes is the same problem with posting pictures. Not trying to flame, but you're ignoring important details.
PostPosted: Sun Sep 09, 2012 11:53 pm
Try photobucket if you can't get the site's attachment to work. Instructions here ----> viewtopic.php?f=5&t=7593
PostPosted: Mon Sep 10, 2012 6:16 pm
PostPosted: Mon Sep 10, 2012 6:17 pm
