It is currently Mon May 25, 2026 1:21 am
 Post subject: sbc motor mounts?
PostPosted: Sun Aug 19, 2012 6:57 pm
can any1 give me ideas on what mounts to use? soild mount vs bushing mounts?
 Post subject: Re: sbc motor mounts?
PostPosted: Thu Aug 23, 2012 5:21 am
Luvkid73
We found it best to always use a rubber or poly mount on the tranny. We now use solid mounts up front and of coarse it vibrates but
its a V8 and those are good vibrations!
Mr.T
PostPosted: Fri Aug 24, 2012 4:44 pm
The only mount i have used is a 67-69 Camaro mount .
PostPosted: Fri Aug 24, 2012 8:34 pm
i like and used mounts out of a 69 chevy c10. and can get new at a auto parts store for around $7.00
PostPosted: Sun Aug 26, 2012 8:20 pm
ok sweet, thank you. where the trans mount bolts to on the truck has to be made longer is that right?
PostPosted: Mon Aug 27, 2012 4:39 pm
Yes , first one i built i extended the factory mount and added angle iron to make it stronger . Second one started with the Hooker mount and ended up with a custom chassis shop mount . New (third or 4th) one will have Hooker .
PostPosted: Mon Aug 27, 2012 7:45 pm
ok thanks, was thinking about making one and bracing it up. might you know where i can find the body bushings for my 73??
PostPosted: Wed Sep 05, 2012 10:34 pm
If you want to see another mount design, look at the www.powerbyace.com piece. That should give you some ideas.
