It is currently Sun Apr 05, 2026 7:39 pm
PostPosted: Sat Aug 18, 2012 3:24 pm
the 73 are dumb drum break, id like to go disc, staying 6 lug to run the new stock sliverado wheels i have. any ideas???
i want to convert my luv to disc break on the frnt, but i want to stay 6lug if possible, im dropping a built 305 motor in the truck.
i know i can use the luv spindles. but i cant find the backing plates and wheel hub. or can i use the hub from the drum breaks???
PostPosted: Sat Aug 18, 2012 8:08 pm
http://www.luvtruck.com/Information/Brake_swap.htm
PostPosted: Sun Aug 19, 2012 3:59 pm
i have read this a few times over, is there a website i can ge all the breaks i need, cuz our junk yards dont have anything close to a luv????
PostPosted: Sun Aug 19, 2012 6:08 pm
Try rockauto.com
PostPosted: Sun Aug 19, 2012 6:37 pm
ok i found my backing plates, and can get the rotors, calipers from my local napa, i just dont know if the studs press into the rotor? or do i need a wheel hub or if i use the hub from my drums?
