It is currently Fri Oct 31, 2025 5:52 am
 Post subject: Smog/Air Pump
PostPosted: Wed Aug 01, 2012 9:45 pm
I have air coming out the vent on top of the pump. I think it should suck air in. The truck backfires when shifting between gears. Don't know if the pump is bad or the switching valves.
76 LUV
 Post subject: Re: Smog/Air Pump
PostPosted: Fri Aug 03, 2012 9:52 pm
Vent on top of the pump is a relief valve. It only opens if the pump pressure exeeds specs. It is either defective itself or--there is a restriction in the output supply hose somewhere. Possible bad diverter valve assy.
PostPosted: Tue Aug 07, 2012 11:08 am
I'm thinking about pulling the belt and letting it go at that.
76 LUV
PostPosted: Tue Aug 07, 2012 5:45 pm
Diverter valve is bad.
PostPosted: Tue Aug 07, 2012 8:30 pm
'76 still requires bi-annual smog so you'll likely have to fix it at some point.
BTW, on our '76, the diverter valve went bad a few times and caused the same symptoms. Eventually my dad did the same thing and just pulled off the belt. Soon after that he pulled all the smog equipment. Then, eventually he had to put it all back on. :lol:
Maybe someday they'll move the smog cutoff up to '85...maybe...
PostPosted: Wed Aug 08, 2012 7:23 am
Has anyone bought a diverter valve lately.
76 LUV
PostPosted: Wed Aug 08, 2012 8:42 am
I probably have a used one in my shed. Wouldn't know if it's any good or not, but might be worth a try if a new one is pricey or unavailable.
PostPosted: Wed Aug 08, 2012 10:18 am
Thanks Rondog. I've checked all the parts stores and no luck. I checked my parts book and it shows 3 valves on this system with the smog/air pump. The Air By-Pass, Mixture Control and Air Switching. Does anyone have a short explanation on how the 3 valves and pump work together (Emissions 101).
76 LUV
PostPosted: Wed Aug 08, 2012 12:33 pm
Have you checked rockauto.com?
PostPosted: Wed Aug 08, 2012 4:21 pm
Nothing from Rock Auto. Can these valves be re-built.
76 LUV
PostPosted: Mon Aug 13, 2012 10:27 pm
I have one... if I'm correct. I'll shoot you a pic of it. It's the one that mounts to the right front corner of the head.
Screw it. I've been trying to make this smaller for 30 mins. I'm just glad I got it to post. :x :oops: :roll: :D
PostPosted: Tue Aug 14, 2012 12:15 am
They say bigger is always better. That looks like the one under the smog pump.
76 LUV
PostPosted: Tue Aug 14, 2012 7:55 am
I forgot about that one. Yea that's probably what it is.
PostPosted: Wed Aug 15, 2012 8:44 pm
Ben, We have a Senator in CA working on that. Bill SB 1224, only got voted down by 1 vote, but plans in the future are going to try and get it through. It will make years 1976 to 1980 Smog exempt.
PostPosted: Thu Aug 16, 2012 11:35 am
I pulled the hose off the pump that goes to the check valve and the pump stopped venting. It was blowing a good amount of air out of the hose. I could feel a vacuum on the check valve. As soon as I put the hose back on the check valve the pump started venting. Could this mean the check valve is bad, not allowing the full amount of air from the pump to pass through the check valve.
76 LUV
PostPosted: Thu Aug 16, 2012 6:50 pm
Yes, it could mean the check valve is just stuck. Take a pencil or something and push in on the check valve. It should allow air to go in one way but not allow exhaust to come back out and damage the pump. Give it a try.
Users browsing this forum: Google [Bot] and 26 guests
