It is currently Mon Jun 08, 2026 12:13 am
 Post subject: Frozen Wheel Hub
PostPosted: Sat Dec 06, 2003 5:18 pm
:?: Recently aquried 1975 Luv and have begun restoration. Trying to change brake shoes and cannot remove wheel hubs?
Need some advice.
Todd
PostPosted: Sat Dec 06, 2003 6:07 pm
I had this problem when i got my LUV. It took some heat (fire wrench) and a very long snipe on the rachet handle, it broke loose eventually. Jumping up and down frantically swearing and cussing helps too.... :lol: Don't heat it up too much it might warp something....
PostPosted: Sat Dec 06, 2003 8:27 pm
This might be a silly question, but, did you remove the screws that hold the brake drum to the hub? Also, hammering around the outside diameter of the brake drum will sometimes break the rust loose. Just don't hammer too hard, you don't want to break the drum.
PostPosted: Sat Dec 06, 2003 10:05 pm
I had a similar problem with an old four wheeler. I ended up getting another guy and we both pried with pry bars on seperate sides. It took awhile back and forth but eventually it broke free. Brute force simple but effective! :twisted:
PostPosted: Sun Dec 07, 2003 1:54 am
i would aply a bit of heat, this will cause expansion and should loosen things up. If you must hit it whith a hammer a bit on the far outside. But make shure you havent forgoten to pull the set screw out
PostPosted: Sun Dec 07, 2003 7:20 pm
i had the same problem on my 80 just pry evenly on the sides like every one else has said. matt
PostPosted: Mon Dec 08, 2003 10:37 am
there is an old saying......
If a first you dont succed....
USE A BIGGER HAMMER!!!!!!!!!!!!
Currently no more luv's... But in search of one!
