It is currently Thu Sep 11, 2025 10:24 am
 Post subject: timing chain
PostPosted: Mon Jul 16, 2012 5:46 pm
i have a 78 the likes to throw timing chains it is a new rebuild and i only get about 150 miles befor it throws it again does anybody know what causes this and how i can fix it
 Post subject: Re: timing chain
PostPosted: Tue Jul 17, 2012 1:21 am
Chain tensioners should hold the chain tight. Make sure you release the tensioner after the chain is installed so it's spring can push against the chain to keep it tight. Push down, turn to the left. You do know about the tensioner adjusment screw I assume?
PostPosted: Tue Jul 17, 2012 11:09 am
Your tensioner could be worn out, too. I would replace it with a new one when you replace the chain.
PostPosted: Thu Jul 19, 2012 4:20 pm
its a brand new tensioner the chain was new too
PostPosted: Thu Jul 19, 2012 11:49 pm
Worn sprockets?
PostPosted: Mon Jul 23, 2012 10:59 am
The sprockets are worn down I have new ones ordered and should have it back up and running soon :D thanx for the help it was much needed :)
