It is currently Mon May 25, 2026 1:22 am
 Post subject: radiator questions
PostPosted: Mon Jul 16, 2012 7:52 pm
ok well i just got my howe aluminum radiator and it didnt have the ports on the bottom for ur trans coolent lines so ppl that use this radiator how do they keep there trans cool? i need answers plz
 Post subject: Re: radiator questions
PostPosted: Mon Jul 16, 2012 10:18 pm
One solution http://www.summitracing.com/search/?key ... oler&dds=1
PostPosted: Tue Jul 17, 2012 10:19 am
Ben wrote:
This is what i did .
PostPosted: Wed Jul 18, 2012 11:18 am
Would that be the only thing I need?
PostPosted: Mon Jul 23, 2012 3:06 am
that should be it. Purchase a transmission cooler and you can either leave your current lines in place and run the correct rubber hose to the cooler and clamp securely or you can cut your stock lines back and run a longer length of hose to clean up your engine bay a bit. Either way works fine.
