It is currently Sun Jun 07, 2026 1:05 pm
 Post subject: LEAK!!
PostPosted: Sun Nov 30, 2003 10:57 pm
Just looking for some opinions...I have a leak on the pass side. If I look up under the dash I can see where it's dripping from. It drips from where the vinyl ends from the headliner, kinda next to the dash. I can't see it leaking from around the windshield seal so I was thinking it might be coming in from the antenna or vent opening or...?? Any ideas on where to start?
Resident lurker
PostPosted: Mon Dec 01, 2003 1:12 pm
i had a 76 jaguar that was leaking water through that vent. the way i found it was i plugged up that vent and ran water all around the area and it didn't leak then i uncovered the vent and let the water hose run in it and it leaked. hope this helps.
PostPosted: Thu Dec 04, 2003 8:40 am
if you can lift up the seal on the outside you should be able to stick the end of some caulking in and squeeze some in there. that is how the windshield guys do it anyway.
03Cobra
PostPosted: Thu Dec 04, 2003 11:50 pm
Thanks guys. I think I found the problem... where the windshield gasket comes together at the bottom of the windshield is separated just a bit. called around to see about getting it replaced and the gasket locally is $57.75 and $125 to remove and reinstall the windshield 8O I had no idea it would be that much so I'm thinking a little black silicone might do it for now. any thoughts??
Resident lurker
PostPosted: Fri Dec 05, 2003 12:36 am
Thats what i would do...theres no leak silicon can't stop! 8)
Users browsing this forum: Bing [Bot] and 23 guests
