It is currently Tue Apr 21, 2026 2:36 am
 Post subject: compresion 4 cyl
PostPosted: Mon Jun 25, 2012 9:35 am
I am doing a 215,000 mile check up, in, around. What is the proper compression for the 4 cylinder engine. And, thank you, in advance, for the assistance.
 Post subject: Re: compresion 4 cyl
PostPosted: Mon Jun 25, 2012 10:33 am
Book says engine series 1-4 should be 160-163
Series 5-12 should be 165-170
PostPosted: Mon Jun 25, 2012 7:53 pm
That's for a new engine, at 215,000 it will be less. Whatever it is it should be within 10psi high to low in all four.
PostPosted: Mon Jun 25, 2012 9:38 pm
Yes Thats true but that's why I put about a 5psi difference but 10 lower is good too..
PostPosted: Tue Jun 26, 2012 8:32 am
Guys,
This really does mess with my head! The truck runs great, uses no oil, gets about 25-28 miles per gallon, and seems to have plenty of power. However, the test showed compression at about 60 on the outside, and 40 on the inside. We are going to get a different tester, just to confirm the low pressure.
Ideas?
thanks,
Ozarkred[/size][/i]
PostPosted: Wed Jun 27, 2012 10:38 pm
That seems really low,I just tested mine,I don'tknow the mileage,5 digit odometer :econfused but mine came up 145 155.
76 mikado project,mean green
PostPosted: Wed Jun 27, 2012 10:43 pm
Tested mine today too.. 168,167,167,168 guess I'm doing pretty darn good :)
PostPosted: Thu Jun 28, 2012 12:23 am
Ozarkred wrote:
Guys,
Ideas?
thanks,
Ozarkred[/size][/i]
Ya doin it correctly? Throttle wide open?
PostPosted: Thu Jun 28, 2012 9:39 am
Ah, ha! No, just at idle speed. Thanks.
Ozarkred
PostPosted: Thu Jun 28, 2012 10:46 am
I hope you meant cranking speed, not idle speed.
Test each cylinder with the throttle wide open, normal cranking speed for 3-8 seconds, all spark plugs removed. Then repeat with a couple teaspoonsful of motor oil into each plug hole, see if there is a significant increase over dry.
PostPosted: Thu Jun 28, 2012 11:37 am
Correct, oil will always make a difference and raise the compression because of the additional room it takes up in the combustion chamber. But--it should not make a major difference in a good engine.
PostPosted: Tue Jul 10, 2012 8:37 pm
If the rings are bad and the valves are bad you will have a drastically lower compression test.
PostPosted: Wed Jul 11, 2012 6:21 am
thank you.
Ozarkred
Users browsing this forum: Google [Bot] and 65 guests
