It is currently Tue Dec 16, 2025 10:10 pm
PostPosted: Mon Jun 04, 2012 10:06 pm
I will be getting a 78 Luv in two weeks. I was wondering if there is a set of calipers to upgrade to?
PostPosted: Tue Jun 05, 2012 2:53 am
Australian LUV Guru
I have fitted vented rotors and calipers from a 84 Isuzu Trooper, all bolt on fitment.
1980 4x4 KBD40 ISUZU/Chev Luv
PostPosted: Thu Jun 07, 2012 2:53 am
When using the Trooper setup, can you still use the LUV spindles and dust shields?
PostPosted: Thu Jun 07, 2012 5:16 am
Australian LUV Guru
Yes & Yes Just unbolt the solid Luv rotor from your hub and bolt on the Trooper vented rotor, calipers are a direct swap over also.
PostPosted: Thu Jun 07, 2012 5:35 am
Excellent! Many thanks!
PostPosted: Thu Jun 07, 2012 7:23 am
Australian LUV Guru
Aftermarket drilled and slotted rotors are available also 8)
PostPosted: Thu Jun 07, 2012 8:06 am
Oz..are aftermarket calipers available down there?
PostPosted: Thu Jun 07, 2012 11:52 am
I have a pair of the vented rotors. Are the trooper calipers 2 piston?
1978 Mikado *Weber 32/36*Offenhauser intake manifold*Pacesetter header*Custom exhaust*Pertronix Ignitor & Flamethrower 40,000v coil*
PostPosted: Thu Jun 07, 2012 12:02 pm
You can be sure that I will be at a Upull yard this weekend buying the Trooper brake parts.
What I really need is a conversion to Chevy 5 lug bolt pattern. Anyone know of that changeover?
Beer Please
PostPosted: Sun Jun 10, 2012 12:48 pm
Hot rod 80 put five lug Toyota parts on his.
PostPosted: Tue Jul 24, 2012 12:06 pm
IS the trooper upgrade applicable to 2WD Luv's as well?
