It is currently Mon May 25, 2026 6:01 am
PostPosted: Fri May 25, 2012 7:43 pm
After painting my sons GMC Jimmy I have decided it's time to probably upgrade from my 30 year old Binks 7 and get a new paint gun. Definitely HVLP gravity feed but I have never used one. I will appreciate any shared knowledge and experiences from anyone who has used any of these.
2005 Silverado 3/4T Crew Cab
1981 Luv 2WD
1995 Roughneck JetBoat
1981 Luv parts trk
PostPosted: Fri May 25, 2012 9:02 pm
I use the same Binks and a Devilbiss... I hate change...
PostPosted: Fri May 25, 2012 9:42 pm
I use a Devilbiss Finishline 3.
PostPosted: Sun May 27, 2012 8:53 am
Out here we use a new system, the waterbase stuff with special guns and air blowers.
PostPosted: Mon May 28, 2012 7:02 am
Thanks for the comments guys. MytMouz, I understand that completely and that is why I have stuck with my Binks all this time. It still shoots great but everyone I talk with tells me if I try one of the HVLP gravity fed guns I will love it. I have at least two more projects coming up soon and now just might be the time to cut my teeth.
I would imagine it shoots the Enamels and Poly's with no problems.?.? Can you get different tips for it?
Luvrv8, I was looking at some Laquer paint at the Du-Pont store and he told me it probably won't be here much longer. He then mentioned you guys in Cali and said it was ilegal for him to even send Laquer products there. He told me about the water based stuff an said it seemed to be good paint. I just don't know anyone up here shooting it.
Thanks for the responses guys.
1981 Luv 2WD
1981 Luv parts trk
PostPosted: Mon May 28, 2012 10:16 am
Yep, I shoot pretty much base coat/clear coat. It came with 4 tips, here is the one I have. (and I now see they have came down in price as I payed a lot more than that 8 years ago. :evil: )
http://www.ebay.com/itm/DeVILBISS-FinishLine-3-HVLP-SPRAY-PAINT-GUN-MASTER-KIT-/200753759205?pt=Motors_Automotive_Tools&hash=item2ebddb43e5&vxp=mtr
PostPosted: Mon May 28, 2012 6:02 pm
I actually like the waterbase stuff. The prep work takes more time, you must do the final sand at 800 grit. After each coat you have to use a air atomizer gun to dry the paint, after 3 coats then wait 45 min for the clear and if done correctly it looks like glass. I painted the hood (cowling) of my Airplane, flew it several times in the rain at 130 MPH and not one flaw.
PostPosted: Mon May 28, 2012 6:32 pm
Thanks for the info about the gun Tilted. I really appreciate it.
Luvrv8, that does sound like a little more work but that is what the paint guy said; he said it actually holds up as well if not better than some other products. I'm sure we will all be using it eventually.
1981 Luv 2WD
1981 Luv parts trk
PostPosted: Tue Jun 05, 2012 12:42 pm
Remember Cali has strict EPA laws. They have no choice. I have heard from several people stuck in Cali that the water based stuff is not too bad, you just have to learn to use it.
PostPosted: Sat Jun 16, 2012 6:35 pm
Just remember you get what you pay for! When I painted at Daktronics they had Valspar bring in their water based stuff..about 97..it sucked.But the new stuff is a lot better. Persona;;y I like acrylic urethane...never sprayed clear.
