It is currently Wed Mar 25, 2026 3:32 am
 Post subject: chevy luv rear end
PostPosted: Tue May 29, 2012 1:26 pm
hello
i have later plans on replacing the stock motor with 350 CHEVY WITH ATTITUDE lol in my 80 luv... so what rear end would i need to use in it ??? i have access to a 4X4 chevy luv as a parts truck may even be able to make it run but would not have a title for it... so would the 4X4 rear end hold up to a chevy motor know that the rearend in my 76 scout didnt had to replace axles 2 times then replace entire rear end.. will plan on all of this when my little 1.8 goes south lol
sammy :lol:
 Post subject: Re: chevy luv rear end
PostPosted: Wed May 30, 2012 11:22 am
2wd & 4wd LUV rears are the same, if you are blowing D44's from a Scout the LUV rear won't last long. Your problem will be finding something stronger that is the right width.
PostPosted: Wed May 30, 2012 12:32 pm
any suggestions for something that is the same size but stronger... maybe a toyota 4wd rearend ??? :?:
sammy
