It is currently Mon May 25, 2026 11:19 pm
 Post subject: power steering??
PostPosted: Wed May 09, 2012 9:32 am
I read the post for the 86 trooper power steering swap but I cant seem to find a 86 trooper donor. wondering what else will work on a 79 4x4 luv.
 Post subject: Re: power steering??
PostPosted: Wed May 09, 2012 2:06 pm
'84 or '85 Trooper will work even better, they used the same engine series as the LUV so any bracketry that bolts to the engine is a direct swap, no mods needed.
PostPosted: Tue May 22, 2012 8:34 pm
how does it attach to the frame is it bolt in or serious modification
PostPosted: Wed May 23, 2012 7:34 pm
Power box bolts to the frame using the same holes as the manual box. I think you may have to enlarge some of the holes. The steering shaft needs modified to mate to the power box.
PostPosted: Wed May 23, 2012 9:40 pm
There's an '88 Trooper 2.3 at the U-Pull-It near me. Would that work?
