It is currently Fri Feb 06, 2026 4:52 pm
 Post subject: 400 luv
PostPosted: Wed May 09, 2012 12:57 pm
ok i am planing on getting a luv and putting a smallblock 400 with 3 speed behind it does anyone have any tips on were to get mounts or anything would help
 Post subject: Re: 400 luv
PostPosted: Wed May 09, 2012 3:09 pm
check out the v8 swap article here ---> http://www.luvtruck.com/pdf/EngSwap.pdf
Summit has weld-in mounts and headers. Powerbyace.com has bolt-in mounts and headers. I have the powerbyace stuff in my truck and I like it. The guy that runs the site is a member here.
Speedway has a good universal radiator for around $115. http://www.speedwaymotors.com/Speedway- ... ,3557.html
PostPosted: Thu May 10, 2012 10:20 am
I run that engine trans combo. I made my own mounts, I wanted my engine lower and farther back then the pre made mounts.
PostPosted: Thu May 10, 2012 10:38 am
well thanks for the info would i have to cand suspetion or rear end?
PostPosted: Thu May 10, 2012 11:02 am
I don't understand the question.
