It is currently Sun Dec 07, 2025 1:52 am
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
 Post subject: Your 5 lug conversion
PostPosted: Sun Nov 25, 2007 12:19 pm
i am currently working on this swap. i used the luv bearring instead and built a spacer so they fit. my question is did you have any problems with the bearings not going on far enough to get the keeper on? The hub seems to wide.
PostPosted: Sun Nov 25, 2007 7:35 pm
The luv bearings where to small to fit the toyota races properly . Your spacers are for Luv bearing races to toyota rotors ?
 Post subject: Re:
PostPosted: Wed Jun 23, 2010 11:54 am
chevyluvss wrote:
Thats actually what im in the process of doing right now. Just swap the ENTIRE spindle/hub assembly over. I'm using an 87 Toy Hilux p/u assems. The lower balljoint was an exact fit. You just need to ream out the upper hole to fit the luv ball joint. I have a good set of Snap-on carbide hone bits that did this in a jiff. My one issue to work past is the tie rod wants to go in from the bottom up, so I might dig some outers and inners up that have an adjustable sleve between them. 60s-70s chev car front ends have the tie rods im thinking of.
Did you us a 10* or a 7* on this and the toyota is a 5 4.5 right? thank you Jason
soon to be luv build
88 tube chassis mustang
Thank you to my sponsors
JnJ Motorsports
Dragon Racing fuels
Redneck performance
Silver Valley SIGNWORKS
PostPosted: Tue May 01, 2012 3:49 am
Attempting to to the Toyota spindle swap at the moment using a dhp upper arm as my lower ones still haven't been sent and not sure if I will ever get them. Problem I'm having is the lower Balljoints don't want to go in to the spindle. The Balljoints is facing downward and the taper on the spindle shows the Balljoints should be facing up. Any ideas on where I'm going wrong? Has me stumped. Using belltech drop spindle part number bel2000
PostPosted: Tue May 01, 2012 4:02 pm
DHP usually uses the Chrysler style joint, and you will need to ream the spindle to fit. Post up a pic of what you are working with...
PostPosted: Tue May 01, 2012 4:13 pm
Only using dhp upper as still havnt got my lowers probably won't. Do the upper fits fine it's the standard lower bj that's not working. Will get pics up in the next few days.
PostPosted: Tue May 01, 2012 8:27 pm
Start a new thread, we are getting off topic with this sticky...
PostPosted: Wed May 08, 2019 11:59 am
I have bought this truck back and will try to take some pictures of it if anyone is still interested in this swap
PostPosted: Thu May 09, 2019 2:28 am
hotrod80 thankyou! i would like to see some pictures of the conversion, i think i understand it but you know pictures always help!
1976 Luv
1980 Isuzu kb 4x4
Nissan GU Patrol
Ford Falcon AU ute
