It is currently Mon Mar 23, 2026 8:40 am
PostPosted: Sun Mar 25, 2012 1:29 am
Hi Guys,
Here's a G180 turbo set up Ive just finished,here's what its got;
-G180
-Precision turbo
-3 Speed automatic trans with transbrake
-Nitrous oxide
-E85 fuel
hp will be between 630-675 on approx 45psi
Hoping to run 8 second qtrs........
Darren
http://www.freewebs.com/gemracing/
PostPosted: Sun Mar 25, 2012 11:19 pm
8O
PostPosted: Sun Mar 25, 2012 11:46 pm
:shocked!:
even after seeing your other engine on ozgemini it amazes me how much you pull from these motors!
45psi is insane 8O how much do you have into the build?
PostPosted: Mon Mar 26, 2012 3:52 am
love4theluv wrote:
:shocked!:
The car will be tuned in a few weeks,then it will be racing soon after that......
Darren
PostPosted: Mon Mar 26, 2012 1:32 pm
make sure you link some videos! i want to see what that little monster can do 8)
PostPosted: Fri Apr 27, 2012 4:26 am
Hi Guys,
We had the car on the dyno last weekend,through the auto and on 28psi,it made 305kw's at the wheels(410hp)(enough to run 9.70's@143mph)..We're going back on tomorrow to see what it makes on 40psi,if all goes well we'll see about 540hp at the tyres,if this car was manual it would be making 600hp at the wheels.....
We still haven't used the nitrous yet.....
I will try and get some video footage too....
Thanks,
Darren
PostPosted: Fri Apr 27, 2012 12:49 pm
good god that thing makes more power than most of the sbcs that they got swapped out for 8)
how much nitrous are you running? with that much power it cant take much
what are you running for the transmission?
PostPosted: Fri Apr 27, 2012 1:00 pm
found a couple of the youtube videos of a previous build of yours
<iframe width="420" height="315" src="http://www.youtube.com/embed/ZNWEUqKEk3c" frameborder="0" allowfullscreen></iframe>
<iframe width="420" height="315" src="http://www.youtube.com/embed/AnAb1MUx3lg" frameborder="0" allowfullscreen></iframe>
PostPosted: Fri Apr 27, 2012 1:22 pm
YouTube links fixed.
PostPosted: Sat Apr 28, 2012 3:38 am
i think i see some rust there in the radiator... other then that um.... cant you guys down under get ahold of some ford mondeo v8's with 6 speeds fairly cheap?
Friends don't let friends drive stock...
76 mikado, emissions delete, dual alternator, rejetted 1.9 carb swap, non factory body lines
soon non points distributor, single (semi sealed beam) head light conversion
PostPosted: Sat Apr 28, 2012 2:05 pm
that would be so much less badass than running a g180 into the 8's tho....
