It is currently Sun Jun 07, 2026 7:31 pm
 Post subject: Wood Dash...??
PostPosted: Tue Jul 21, 2009 12:52 pm
So seeing is how my dash is basically torn to shreds i was thinking of making a wooden dash. Anyone think its a good idea, or even worth it?? I was thinking cherry wood...
 Post subject: Re: Wood Dash...??
PostPosted: Tue Jul 21, 2009 11:22 pm
A wood dash.....hmmmmm. I am a novice wood worker when it comes to finished products of that type so I don't think I could attempt it myself. Would you make it from laminate strips to conform to the original dash design or come up with a different concept? If you make one post some pics.
2005 Silverado 3/4T Crew Cab
1981 Luv 2WD
1995 Roughneck JetBoat
1981 Luv parts trk
PostPosted: Tue Jul 21, 2009 11:49 pm
I was actually just thinkin of making it out of a solid peace of wood, kinda of like wood carvers due with those sculpted bears on the side of the road... And i was going to kind of conform to make it look like the original dash put put my own spin on it...
PostPosted: Wed Jul 22, 2009 11:29 am
I would be concerned about drying out and splitting/cracking. Would using a layer of foberglass cloth and epoxy resin over the entire thing seal it and protect it? I built a canoe years ago and glassed it like that for protection and the cloth was invisible. It sat outside for a few years and had no problems.
Rick
Loranger, La
1980 Stepside LUV (Again)
PostPosted: Wed Jul 22, 2009 4:35 pm
I thought about doing a wood dash too, when you get it done you could use it for a die and make fiberglass dashes out of the mold. I thought if you could find a doner truck and cut out the dash it would be a lot easier to make the master from.
PostPosted: Wed Jul 22, 2009 7:46 pm
An intriguing idea. My 77's dash is metal with about a 3/4'' layer of foam over it. Old cracked foam with vinyl fabric patches that didn't work that well. I did hack a hole in the top to make room for a AM/FM/cassette stereo. I welded some braces in in case what I cut out was structural.
I am not sure about the whole dash. Of course, a big slab of wood securely attached should give rigidity too. You could do some things like make a good place for more gauges. I only have speedo, fuel and temperature. You could also bore some holes to provide cup holders. I used something meant to mount on the transmission to hide the top of the radio.
The sun will slowly destroy the upper level of wood causing even the very best varnish to crack and peel. I think if you started with a well cured piece of wood and used an oil or wax finish, it might hold up. Just rewax now and then.
PostPosted: Wed Jul 22, 2009 10:22 pm
Well i figured i would reseal and wax it maybe every year, just like you would with a deck that you really like. I may be getting an old 4x4 i use to have back, so i might use that dash as a form for the wood one. I actually think i will go through with it. The only guages i would think i would keep are spd, tach, temp, gas, and oil pressure. I dont think making it will really be that complicated, plus it would look sick...
PostPosted: Thu Jul 23, 2009 5:49 am
The walnut panels in the high end stuff always seemed to hold up.
PostPosted: Fri Apr 13, 2012 3:15 am
not shear what they use but if you look up what kind of wood they use on the old fishing boats if it can handle salt water and sun all day it can handle anything
PostPosted: Fri Apr 13, 2012 6:03 pm
I think it is Teak. It isn't cheap either, but looks beautiful when properly finished.
Rick
Loranger, La
PostPosted: Sat Apr 14, 2012 6:16 am
Maybe try Varithane(spelling?).It is a liquid plastic sealer/varnish.when I refinished some pool cues we used it and it work great.Wopuldn't have to worry about condensation that way.
PostPosted: Sat Apr 14, 2012 7:45 am
You guys do realize how old this post is and the guy hasnt been here in almost 2 years right?
PostPosted: Sat Apr 14, 2012 4:50 pm
aaa, who looks at dates? :lol:
Rick
Loranger, La
