It is currently Mon May 25, 2026 10:47 pm
PostPosted: Sun Apr 01, 2012 8:00 pm
I have a 1980. Is it easy to change the headlamps from 2 to 4 lamps? Does the single headlamp bucket swap out with the dual version? I know the grill would have to be replaced but is all of this plug and play?
PostPosted: Mon Apr 02, 2012 11:16 am
Yes its plug and play i converted my 78 frontend to a 75 and luv it!!!
PostPosted: Mon Apr 02, 2012 12:56 pm
So, what do I need in terms of parts? I am assuming;
1.) New Grill (What years work?)
2.) 2 new headlamp pockets (What years work?)
3.) 2 new dual headlamp bezels (What years work?)
4.) 2 new lamps
5.) Anything else?????
Thanks.
PostPosted: Mon Apr 02, 2012 1:21 pm
72-77 were the 4 headlight years.
PostPosted: Mon Apr 02, 2012 6:11 pm
The later trucks (2 headlamp system) do not have fuses for the extra high beam bulbs. I am converting to a 4 lamp system and will use the high beam signal to run a relay with power from the battery direct with inline fuses.
PostPosted: Tue Apr 03, 2012 9:25 am
Good point. Thanks for the info. How readily available are the cans, bezels, etc???
PostPosted: Tue Apr 03, 2012 10:18 am
They pop up time to time on here and ebay.
PostPosted: Tue Apr 17, 2012 11:09 pm
so is there a reason you all are upgrading/downgrading from single 7" to dual 5 3/4" head lights? other then say looks?
your also going to have to rewire the head light pig tail to run power to the inside light
(unless you want to run dual high/low) then run all 4 light for high/low beam (h4 pig tail you can find them on ebay)
PostPosted: Tue Apr 17, 2012 11:40 pm
Pm me i have 3 complete sets with bezels i will send pics if you would like all are in super shape no cracks or fading.
LIVE HARD PLAY HARDER
