It is currently Mon Mar 16, 2026 10:44 pm
Post new topic Reply to topic  [ 58 posts ]  Go to page 1, 2, 3  Next
 Post subject: Couple of LUV projects
PostPosted: Thu Sep 15, 2011 9:10 pm
Got a couple of different projects going
Luv #1
-2x3 frame, will be full caged front to back with 1 3/4 .120 wall tube
-14 bolt rear, dana 60 front
-350/th350/np205
-42" swampers
-Full hydro steering
-Deaver rear leaf springs, sprung under
-Front four link, 16 inch coilovers
Luv #2
Picked this pile up for $400, drove it home. Needs a clutch BADLY. Slips so bad you can put the truck in gear, let off the clutch and it won't die or move :lol: . Cranked the torsion bars down on the front, ordered a clutch kit and some lowering blocks. Needs a lot of general maintanance, and some wiring help. Will slowly get it sanded down and throw some paint at it
PostPosted: Mon Sep 19, 2011 8:17 pm
badass..i like your style!
PostPosted: Tue Sep 20, 2011 12:26 am
what he said 8O
i cant wait to see that 4x4 done!
PostPosted: Tue Sep 20, 2011 1:06 am
:smt023
PostPosted: Tue Sep 20, 2011 4:50 pm
Nice welds!
1974 Mikado 4x4 50,000 orig. miles
PostPosted: Sun Oct 23, 2011 3:18 pm
Got a good part of the interior cage done, started the truss on the front axle. Motor is also mounted.
PostPosted: Sun Oct 23, 2011 11:11 pm
Lookin Sweet!!
Epic Fabrication.
KAOS
PostPosted: Tue Nov 01, 2011 11:14 pm
kaotikluv wrote:
Lookin Sweet!!
Thanks
This hot hooker strolled in Saturday evening.
Found this mummified mouse
Got the truss all cut out, and the lower links attached
PostPosted: Wed Nov 02, 2011 10:14 am
I don't think I could drink enough for her to look good. :)
Nice fab job though!
PostPosted: Wed Nov 02, 2011 11:56 am
SMOG! I bet I know what killed the mouse...
PostPosted: Thu Nov 03, 2011 8:35 pm
:lol: , thanks
My theory is that merely had too much to drink the night before, and is simply dehydrated. What do you think got him? :eugeek
More updates
I was grinding some brackets, I turn around, and this cupcake has appeared out of nowhere. Fawkin magic!
Got some more done on the truck
PostPosted: Wed Nov 09, 2011 9:19 pm
Teaser
PostPosted: Wed Nov 23, 2011 8:25 pm
Had to keep the forward tilt hood of course
PostPosted: Tue Dec 27, 2011 12:45 am
Haven't done a lot with the truck. I started on the rear tube work, and started cutting the front fenders for the dove nose. Also decided to go spring over
Been helping this idiot put his Toyota together
Rear tube, not sure what behind this is going to look like
First cut on the fender
PostPosted: Sun Feb 26, 2012 6:39 pm
Been working on some other stuff for a while. Getting back to working on this thing, but decided to clean up the stall first. Rolled it outside for it's first breath of fresh air in a while. Front suspension is at full compression, rear is about two inches away
PostPosted: Tue Feb 28, 2012 10:52 pm
Started mounting the fuel cell. Radiator is also going to end up back here somewhere
Start of the fuel cell straps, will have these finished and on tomorrow night after work.
PostPosted: Thu Mar 01, 2012 2:19 am
Cell got strapped
PostPosted: Fri Mar 02, 2012 5:02 am
man that thing is looking good!
come up with any ideas for the rear end once its finished?
are the front fenders narrowed?
PostPosted: Sun Mar 04, 2012 12:27 am
Thanks, not really any idea yet, once I start hanging bedsides on it I'm sure I'll figure something out. The nose is in the process of being narrowed
PostPosted: Fri Mar 09, 2012 11:47 pm
Radiator is mounted. I'm going to shove a artec quart crate between it and the fuel cell, then a couple of batteries are going to be mounted right behind the cab.
