It is currently Tue Apr 14, 2026 7:32 pm
PostPosted: Sat Jan 21, 2012 8:22 pm
I need to know what the bell housing bolt pattern is for a 82 Chevy luv with the 2.2 deisel motor. If any of you know what it is or a link for me to find it that would be so so helpful! Thanks!
PostPosted: Sun Jan 22, 2012 12:50 am
Can you clarify your question?
PostPosted: Sun Jan 22, 2012 1:49 pm
Ok I recently pulled my engine out and replaced the rear main seal and oil pan gasket and put a new head set on. Right now I'm in the process of putting the motor back in. Now on my bell housing the bolts that I have for it are different sizes. Some are long and fat and some a shorter and a little skinnier and some had nuts on the back and some didn't. I completely forgot where they each went I just know they go on the bell housing. So I'm wondering if anyone knows a bolt pattern or a diagram or something that would help me out? Also is it common for there to be so many different sizes on it? Thanks!
PostPosted: Sun Jan 22, 2012 9:47 pm
The two largest ones (with nuts) hold the starter on. I don't remember the others being different sizes.
PostPosted: Sun Jan 22, 2012 10:53 pm
Ok I will check it out tomorrow, are those ones very long?
PostPosted: Mon Jan 23, 2012 8:28 am
The starter bolts are larger and longer, and they have nuts on them. Seems like they were about 4". They're too large to fit any of the other holes.
PostPosted: Mon Jan 23, 2012 4:31 pm
Ok I got the two bolts on the starter and put the head on, I didn't have time to check out the rest of the bolts for the bell housing. Thanks for the help there! I would've never found this out haha
PostPosted: Mon Jan 23, 2012 8:20 pm
You're aware the transmission has to go on BEFORE you bolt the starter, right?
PostPosted: Mon Jan 23, 2012 8:44 pm
Ya the tranny is in
