It is currently Mon Jun 29, 2026 12:08 pm
PostPosted: Fri Jan 06, 2012 11:11 pm
I am replacing my front axles with new ones as my CV joint boots were torn and I want to freshen everything up. I have the axle assemblies pulled but am stuck at the point where the manual says to "Press Off" the inner bearings after removing the C-clips, and then reinstall the bearings on the new axles. I'd rather just add new bearings while I'm in there and would like to take the shaft assemblies along with new bearings to the machine shop to do the press work. I went to Napa to order them and they don't show a part# for them?
I'm completely new to dealing with CV joints, half shafts, etc.
Any suggestions?
PostPosted: Fri Jan 06, 2012 11:36 pm
What year is your LUV?
PostPosted: Sat Jan 07, 2012 12:17 am
1980 4x4
PostPosted: Sat Jan 14, 2012 5:51 pm
Have you tried Rockauto.com I've got alot of stuff from them and everything fit.
