It is currently Sun May 10, 2026 3:21 am
 Post subject: 2.6 HELP!!!
PostPosted: Thu Dec 29, 2011 3:17 am
ok so i have an 85 trooper 2 it is all stock it has the g 200 w a/c and the 4 spd manual the piston rings are shot in the g 200 so i now have the 2.6 out of a 90 4 dr trooper and i want to put it in my trooper i've read some things here and there but i now need hard facts as to what i have in front of me (1. clutch size (2.fire wall (3. oil pan the 2.6 is a two piece deep sump pan (4.motor mounts (5. fuel pump, i have the pump from the tank and i need to wire it or something else and the relays for the pump and anything else i am missing i have all of the engine ecu wiring i don't want this project to stall out and not be completed so i am in need of help all and any i can get would so help full and if any one wants to help wrench to thats would be awsome to thank you steven
 Post subject: Re: 2.6 HELP!!!
PostPosted: Fri Jan 06, 2012 9:56 pm
There is an isuzu website alot like this one. Not sure of the exact site name but a google search might help you find it.
2005 Silverado 3/4T Crew Cab
1981 Luv 2WD
1995 Roughneck JetBoat
1981 Luv parts trk
PostPosted: Fri Jan 06, 2012 11:56 pm
might be a good start
http://www.ozgemini.com
http://forum.planetisuzoo.com
