It is currently Thu Jan 01, 2026 6:52 am
Post new topic Reply to topic  [ 558 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 28  Next
PostPosted: Thu Oct 20, 2011 6:54 pm
just a couple pics to show the difference between the impulse turbo manifolds and the stock manifolds
stock setup
Impulse turbo setup
this is as "bolt on" as any turbo swap you will ever find.
impulse turbo is a borg-warner IHI RHB5 (i believe the same as the ford thunderbird but dont quote me on that)
the manifolds have the same bolt pattern etc you can pull your old ones off and throw these ones on with very little effort
PostPosted: Thu Oct 20, 2011 10:52 pm
Hope it's not as easy to throw your rods...
PostPosted: Fri Oct 21, 2011 3:03 am
me too :lol:
i will be setting this all up on my spare engine after i finish going thru it and getting the head redone, cylinders honed, new bearings etc....
i wont be pushing extreme boost for quite a while... will keep it at the stock setting for a while and raise it once i trust the system can handle it...
may be converting to propane... cheaper to run than high octane (91+) gas, and with an average of 104-105 octane it should be more forgiving but still deciding on a setup... may stick with gas. next stage is fuel system so i will be deciding while i save up..
wont even be running this setup until i have got everything setup on my second engine for it, not worth destroying my daily driver cuz i wanted to boost it before its able to handle it.
PostPosted: Fri Oct 21, 2011 7:07 am
You will lose 10% of your fuel mileage with propane, If you even care :lol:.
Propane + high compression head + Turbo = :twisted:
If you haven't looked at propane components I would give Cary a call at gotpropane, Hes the propane + turbo king.
PostPosted: Sat Oct 22, 2011 12:28 am
i gotta get my head decked anyway be because of a few gouges so it will bump compression up a bit :lol:
im looking into a few setups.. will likely end up running an impco 225 or 300 mixer in a blow thru setup, smallish front mount, etc
when the time comes to buy the setup i will be giving gotpropane a call and see what they have that will work for me. their website gave me a lot of the info that pushed me to the setup
and eh.... 10% less fuel economy for a fuel that doesnt leave carbon deposits in the engine and blacken the oil, costs 3.24 a gal (vs 3.60 in winter and around $4 in summer for 87 octane) AND is 105 octane.... i will give that 10% gladly for the reassurance my motor wont go PING... BOOM
ahh if only i had an unlimited budget :roll:
PostPosted: Sat Oct 22, 2011 2:29 am
pretty much decided on propane. just need to save up for the parts and tank
PostPosted: Sat Oct 22, 2011 7:32 am
On the egine rebuild I would have it balanced and have the deck shaved you'll be boosting that thing so you want it to stay together.
PostPosted: Sat Oct 22, 2011 12:39 pm
yep the tighter i can keep the tolerances the better :lol:
im not in a huge hurry to throw it together still need to save up $$$ for the machine work and the propane conversion parts.
im hoping that bumping the compression up a bit will give me some more umph down low while im off boost then have it really come into its own once the turbo spools.
im thinking around 180hp would be a great point to aim for until i can get forged pistons and all the internal goodies, would be a huge improvement over stock to say the least :lol: :lol:
PostPosted: Fri Nov 11, 2011 5:56 pm
can you say beautiful?
lol just got my spare head back from the machinist today. its going on in the morning will get some pics of the process :D
PostPosted: Sat Nov 19, 2011 10:33 pm
got the new head on and man it runs smooth 8)
still smokes at 60 so on to the rings :roll: found a 5 speed im buying so hopefully i can get them both done while the engine is out
PostPosted: Fri Dec 02, 2011 5:29 pm
Hows it goin? hows the motor coming? any more news? 8)
PostPosted: Sat Dec 03, 2011 1:31 am
well popped my hood with it running and noticed oil being pushed out of the dipstick, god pissed and spent a few mins trying to find the source of the back pressure... PCV was blocked off... opened it up to vent straight out under the hood and no smoking since and i have been abusing the life out of it to see if it will do it again and none yet!
im waiting for my license suspension before i really tear into it. my turbo manifold has a crack :cry: so i waiting for my uncle to take a look at it and see if he can save it..
still doing my research and planning the layout while i have the time.
PostPosted: Sat Dec 24, 2011 1:36 am
well decided i dont want to spend over $2000 to set up a reliable turbocharged 1.8... im just gonna grab a 4.3 to throw in... add a couple pounds but get the same power a turbo g180 would give me for 1/3 the price with way more torque down low :ebiggrin
off to pick-n-pull tomorrow to see if i can find myself a v6 birthday present :)
looking for the older 85-86 carbed model to make it a lil quicker of a swap... if i cant find one i will get a tbi engine, sell the tbi system and swap it to the carb intake before i drop it in :roll:
i have less than 3 months to get it done so i think this will be much more practical.
PostPosted: Thu Dec 29, 2011 4:07 pm
i found my 4.3 :D
pout an ad on craigslist and got an offer for one the next day.
91 s10 so after they worked out the bugs in the 700r4.
and for only $425 for engine and trans with 133k miles running but how well it was running i do not know lo. will be going to look it over and pick it up on the 7th of january so hoping to have some progress to show soon :ebiggrin
PostPosted: Mon Jan 02, 2012 12:43 am
Any more News? How you gona do your transfer case? If your gona keep it 4x4?
A 4.3 will be Sweet!!!!
PostPosted: Mon Jan 02, 2012 1:28 am
for the time being it will have to be 2wd since the t case on the 4.3 is a driver side diff and the luv is passenger side...
i would really like to find a set of jeep cherokee axles to throw under it one of these days when i have some more money to throw at it. would be my best solution to getting back to 4x4, and would also get me a solid front axle and a much better selection of gear ratios and lifts etc
as of right now tho all im worrying about is getting the 4.3 swap under way. few more days till i go cheak the engine out. going to have to get the carbed intake and distributor from an 85-86 astro or truck to convert the one im getting and save myself a few weeks of chasing down bad sensors and finding an ecu and wiring harness.
as soon as i have some progress to show i will post it up and get some pics of the new engine and trans etc..
PostPosted: Mon Jan 02, 2012 1:45 am
I gotcha! Yea Id just do jeep axle and coils. If i was building another one thats what i would do anyway. :lol: I cant wait to get into my Wiring :lol: Ill have alot thats forsure! Well post up when you got some updates!
PostPosted: Fri Jan 06, 2012 5:25 pm
picking up my 4.3 and 700r4 4x4 trans tomorrow noonish with my younger brother should be pretty quick... (gotta say younger since he has 100lbs and 7" on me :lol: )
will upload pics of everything when i get back home with it :D
gonna be another week or so to hunt down the carbureted intake and quadrajet for it.. not gonna deal with the tbi just dropping in a carb :lol:
PostPosted: Sat Jan 07, 2012 6:09 pm
brought my new 4.3/700r4 home today :D
transfer case drops on the driver side so looks like im going to need to swap to a different front axle.. straight jeep maybe? :egeek
the engine looks like its in real good shape. i will get a few pics tonight when i get it a bit cleaned up and get some light on it.
next step... yank off all the emissions crap, a/c compressor, power steering pump (saving that), Tbi/intake and distributor and get it ready for the 4 bbl q jet and hei :ebiggrin old truck needs old style parts on it none of the electronic crap :roll:
also the 700r4 i got has a K on the case.. i read that this is the more "refined" and a bit stronger than the older one.. can anyone verify that?
PostPosted: Sat Jan 07, 2012 8:12 pm
You can get an adaptor for get a newer syle transfer case or just get an 90s case and keep your 4x4? Im not sure but I know you can find the info online, so you can keep your stock 4x4 for right now and when your ready to do your straight axle bluild you just throw toy axles in! haha :D Im pretty sure there passager side diff. Just an Idea anyway haha. Rather than getting a 2wd output shaved and doin that.(unless you were just gona run the transfer case) Your gona have to get drive lines made. just food for thought! :popcorn: :popcorn: PICS!!!
Users browsing this forum: No registered users and 1 guest
