It is currently Mon May 25, 2026 4:23 am
 Post subject: Lift
PostPosted: Fri Dec 09, 2011 10:54 pm
Want to put a lift, anything I should know?
 Post subject: Re: Lift
PostPosted: Sat Dec 17, 2011 6:34 pm
righty-tighty, lefty-loosey
PostPosted: Sat Dec 17, 2011 7:48 pm
How you gona lift it? Your pretty limited. What are you gona do? body lift? or T-bar crank? or trooper control arms? these are pretty much it for bolt on.
PostPosted: Wed Jan 04, 2012 2:12 pm
lifting the rear is fairly easy drop shackles, add a leaf, longer springs... 2" body lift, front is the hard part... cranking the tortion bars or drop spindals
Friends don't let friends drive stock...
76 mikado, emissions delete, dual alternator, rejetted 1.9 carb swap, non factory body lines
soon non points distributor, single (semi sealed beam) head light conversion
Users browsing this forum: Google [Bot] and 16 guests
