It is currently Mon Mar 30, 2026 11:01 pm
PostPosted: Fri Oct 31, 2003 3:58 pm
JUST THOUGHT YOU GUYS MIGHT BE INTERESTED IN A WEB SIGHT THAT HAS A HOMEMADE RECIPE FOR OCTANE BOOSTER. HTTP://WWW.vtr.org/maintain/gasoline-octane.html
PostPosted: Thu Nov 20, 2003 9:51 am
have you tried it out i scratch my head i am a little bit effie on it
PostPosted: Thu Nov 20, 2003 10:03 am
:lol:Sounds kinda scarry dose'nt it. No i havent tried it :? I just been going to my local small airport to get higher octane for a pump mix.
PostPosted: Thu Nov 20, 2003 12:28 pm
they sell it to ya ? thats illegal as hell.
we have 100ll avgas, auto gas, dyed diesel fuel, diesel, and jet-a.
i get guys all the time that come in wanting some 100ll. it has to go into a tanker truck and they have to sign a petition saying it's not going in a drag car. if you were a little closer to me i could get you all the gas you want.
i run 100ll in my cars to keep the engines clean. you gotta watch how much you mix in though. usaully 3 to 4 cups to a full tank of gas. anymore than that you'll blow your head.
PostPosted: Thu Nov 20, 2003 1:42 pm
here in monroe i can go to the little airport and buy 103 octane fuel right off a pump. its a little pricey but, so is the the rest of the gas.
Currently no more luv's... But in search of one!
PostPosted: Thu Nov 20, 2003 11:26 pm
103.....ssshhh.....thats not suposed to be public knowledge.... 8) mixen is trixen...Just have the need for speed...please excuse me...R.P.M. junkie here ......and you???????
PostPosted: Fri Nov 21, 2003 4:54 pm
But just who exactly is gonna drive to monroe and try to find the airport just to 103 octane fuel? oh, by the way, you may be an RPM junkie, but im a speed junkie. ive almost killed my self probably 100 times just on my dirtbike, ive jumped my luv about 8 feet in the air, and many more things, including doing 135 while outrunnig a cop.
PostPosted: Sat Nov 22, 2003 10:17 am
Actually, I have heard of a couple people using that same formula to make their own mix. Its supposed to work pretty good. I would use the same formula but add a little more gas to it the first couple times to make sure its kosher.
Hey look! I'm a regular!
No LUV anymore, but still in the GM truck family. Running a lifted 2002 Silverado Z-71!
PostPosted: Sun Nov 23, 2003 10:05 am
alright well jus wait for someone smart to use it in their luv and tell us :lol: but that was nice to share the recipes that av gas you have to be extremely careful around it jus the little amount of stactic electricity and boom by the way dont put it in a plastic container yikes i used to help out at a local airport waxing planes learned some stuff
PostPosted: Sun Nov 23, 2003 10:07 am
by the way they sell race fuel in our nickle ads i think there is 108 105 and something else i ll check into it again
PostPosted: Tue Feb 03, 2004 9:03 pm
I have used the fromulas there many times to make octane boost.
I run 94.3 or so in my T-type for when I am looking for some imports to kill.
rest of the time around 89
with 94.3 14.78 run
with 89.0 15.00 run
rigel
81 LUV 4x4 Red Was a heavy hauler now is back to mostly stock config.
http://www.Rigeltech.com
PostPosted: Tue Feb 03, 2004 9:11 pm
i wasn't aware that it was illegal to buy aviation fuel for off highway use. the only reason that it's illegal to run on the road is because it isn't taxed like road gas
PostPosted: Tue Feb 03, 2004 9:56 pm
OG Lifer
BCG, be careful about running any of that shitty aviation crap in your truck. It says 100LL, but it is still a leaded fuel. You will get lots of lead deposits in your engine. I have cleaned tons of lead deposits out of aircraft sparkplugs. It is not the easiest shit to get off either. The line guys here ran that stuff in the tugs, and burned up the valves in the heads. The lead deposits in your engine will heat up, and not burn. You also have the chance for detonation.
BTW, running from cops is the stupidest thing anyone could ever do. If they are chasing you, then you must have broken the law. They are only doing their jobs.
WATCH YOUR PIEHOLE!!!!!!
PostPosted: Wed Feb 04, 2004 12:30 am
Hel, I can get racing fuel at the Local BP. And there isn't even a race track within 200 miles of where I'm at.
The closest one is Rockingham Raceway.
PostPosted: Wed Feb 04, 2004 7:51 am
Guess Im livin in the right town. Weve got maybe 5 stations that sell different race gases and a small circle track that sells to the public also. And Ive heard of people around here buying aviation fuel from the small airport here also. Why I dont know when we have stations selling the stuff they should be using. And for the idiot trying to out run cops, I hope you never kill someone else when your time is up.
PostPosted: Wed Feb 04, 2004 5:06 pm
OG Lifer
Amen.
PostPosted: Mon Feb 09, 2004 2:32 pm
The alcohol would work great, it is the same as cleaner buring ethanol blended gasoline wi have up here in Canada, is a little harder on fuel system components, but helps the engine run better, and is like putting carb cleaner through with the gas as it cleans as it flows through the engine
PostPosted: Mon Feb 09, 2004 3:54 pm
8O 8O 8O Your from Canada!!! And hell your even in the same damn city im in!! ........guys i think i finally found a friend :cry: ...... :lol: Spill some guts about yourself and where you are in this pathetic city, maybe we can have our own LUV Truck Meet 8) 8) Here i thought i was the only guy in Canada with a LUV :lol: :lol: :D
PostPosted: Mon Feb 09, 2004 5:56 pm
I helped my buddy work on his LUV, got me hooked, now I am looking for one. Currently in Engineering at the university here.
PostPosted: Mon Feb 09, 2004 6:11 pm
Sweet man, luv to here of another guy getting hooked on LUV! Wheres your buddy from?? Fuck we gotta find you a LUV and bring the LUV population up! Are you from the city or from out of town?
