It is currently Fri Mar 20, 2026 5:36 am
 Post subject: fuel pump relay location
PostPosted: Tue Nov 29, 2011 7:45 pm
OK guys I have a dumb one...is the relay inside the cab or of the firewall in the engine bay.Kept blowing fuses Saturday and have it "engineered" so I have to disconnect it when I shut the key off.
PostPosted: Tue Nov 29, 2011 8:02 pm
Under the cover on the pic, behind the washer fluid bottle.
PostPosted: Tue Nov 29, 2011 8:19 pm
Thanks!
PostPosted: Thu Dec 01, 2011 8:22 am
ok.no plate and no relay! Anybody know if there is still a relay available?
PostPosted: Thu Dec 01, 2011 9:06 pm
The fuel pump relay is located behind the shiney cover on the right rear side of the engine compartment. However unless you still have the stock alternator and voltage regulator the fuel pump relay is not working anyway!
There are numerous posts on here regarding how this system works but to shorten the explanation, unless the stock alternator's voltage regulator works the fuel pump relay is not activated.
Most guys have bypassed this relay anyway by now, they just run the wire going to the fuel pump to a 12V switched scource.
As stated read through the posts and you can find your answer.
Good luck,
dp
PostPosted: Thu Dec 01, 2011 9:44 pm
There is not a plate or relay as in previous post. I was asking if anyone could tell me the part number for a relay.
PostPosted: Sat Dec 03, 2011 12:13 pm
I believe someone has already snswered this, but here goes. Finding the exact relay may be difficult, however you can buy one just like the stock one at any parts shop, Auto Zone, Pep boys, or even Radio Shack, these are all alike. You can buy a HD one 34-40 amp if needed by buying a aux driving light kit, then you get the switch, wiring, relay and instruction all in a package.
dp
PostPosted: Sat Dec 03, 2011 2:18 pm
I found this post through search, hopefully it will help.
http://forums.luvtruck.com/viewtopic.php?f=5&t=5061
PostPosted: Sat Dec 03, 2011 3:18 pm
Thanks Tilted.My truck has the plate and relay missing.The wire they used to bypass the relay is fried and I wanted to do it a safer way! Thanks again....I had searched for a fuel relay on the site but it just gave me references to other relays!
Users browsing this forum: Bing [Bot], Majestic-12 [Bot] and 35 guests
