It is currently Wed Mar 18, 2026 11:27 pm
 Post subject: 1978 Luv Stepside
PostPosted: Wed Nov 09, 2011 7:44 pm
Hello, Im new to the forum , and have zero knowledge of wheel fitment of above make . I just purchased above truck and was wondering if some of the pros on here could awnser some of my questions etc . I have a unfired [new ] Musi 421 that I will be installing in my truck with a powerglide and a Dana - 60 , my first question is how big of a tire can be installed on above stepside truck without tubbing rearend etc , does the stepside model have any advantages with width issues over standard bed . I would like to run Cal-trac bars with the springs they make also , thanks Chris
 Post subject: Re: 1978 Luv Stepside
PostPosted: Thu Nov 10, 2011 12:34 am
Congratulation Chris,
Sounds like you've got quite a project going, If you build the Dana 60 rear end with a 51" span (backing plate to backing plate) your choice of tires is unlimited, but you will probably have to find some wheels with a 3 1/2 backspace to avoid spring interference. There are several articles on this site that show how you can move your springs inboard if desired.
Good luck, dp
PostPosted: Thu Nov 10, 2011 1:43 am
Actually, tire width is slightly smaller than the fleetside beds on the most common stepside beds. (there are 3 versions, I believe, the one like I have on my avatar truck has the flaired bottom wheel edges is slightly wider than the rest). A 10 inch wide tire is going to be tricky, anything more than that will require some surgery...
PostPosted: Thu Nov 10, 2011 5:39 am
With perfect measurements and the correct backspace a 10.5 will work . Tire height as you know is not an issue , as a 30 inch tire will fit . Terry is correct in that the step bed sides extend about an inch past the frame rails . The fleet beds are at or very close to flush with the frame rails . We also need a picture of the bed . I have 2 different sets of rear fenders for mine and the flared set allow for an extra inch of tire . The step beds were dealer options . As i understand it , trucks came over from Japan without the beds so they were assembled in the USA .
Oh and welcome to the forum
PostPosted: Thu Nov 10, 2011 9:59 pm
Thanks for all the info I will get a picture of bed so I only waste money one time , I usually buy everything [ 2 to 3 times ] before it fits ,,, I wil send some photos again thankyou [ ALL ] for help Chris
PostPosted: Fri Nov 11, 2011 9:08 pm
Just for the hell of it How many beds were made ? who made them and what were they called ? I have always wondered .
PostPosted: Sat Nov 12, 2011 12:15 pm
viewtopic.php?f=5&t=22062&hilit=stepside
PostPosted: Sat Nov 12, 2011 3:50 pm
Search button is amazing . Tryin to help a noob out .
PostPosted: Mon Nov 14, 2011 7:50 am
along with the two style of fenders ctmandu mentions there apparently was a "starside" bed... http://www.luvtruck.com/Gallery/MikeBai ... index.html
PostPosted: Mon Nov 14, 2011 9:04 am
That reminds me of the Vette in corvette summer .
PostPosted: Mon Nov 14, 2011 9:17 am
Lol... thats what i thought when i first saw it
PostPosted: Mon Nov 14, 2011 11:49 am
:smt078
PostPosted: Mon Nov 14, 2011 11:28 pm
exactly... :signiagree
PostPosted: Tue Nov 15, 2011 7:10 am
I totally forgot about those starside beds. Lucky for all of us they faded fast.
PostPosted: Tue Nov 15, 2011 7:42 am
IMO they are not well suited for the LUV's body lines... Very dated also..
PostPosted: Tue Nov 15, 2011 7:54 am
This is the bed he actually has . The tailgate is different then mine . It doent have the side steps . and it has the gas filler . My fenders like this don't have the gas filler .
http://webmaila.netzero.net/webmail/new ... 1525672056
PostPosted: Tue Nov 15, 2011 5:10 pm
Link no workhouse... IDK your login...
PostPosted: Tue Nov 15, 2011 5:12 pm
Yea i dont either .
