It is currently Tue Jun 09, 2026 1:45 pm
 Post subject: strange noise
PostPosted: Sat Nov 22, 2003 11:52 am
i hear this type of whistling/hum noise after i slow down from goin above 50mph i cant tell if its from the tranny or the engine i am thinkin it might be the tranny :?:
PostPosted: Sat Nov 22, 2003 1:12 pm
Freind of mine had a cutlass that had a similar noise. Ended up being something in the trans.
PostPosted: Sat Nov 22, 2003 1:59 pm
i will check to see if it is low on oil in the tranny never checked it :?
do you think it may be a bearing also :?:
PostPosted: Sat Nov 22, 2003 10:09 pm
i am so mad i rounded the filler plug bolt on my trannyusing the boxed end and already drained the oil :evil: i tried using vise grips, torch, tried hammer tappin the bolt but somebody might have put locktite on it or welded it on dang before all that i found that past owner put sae 30 oil in my rear end it wasn't 90w oil 8O it jus makes me mad i jus had to get this off my chest sorry you had to read this i feel better now :)
PostPosted: Sun Nov 23, 2003 10:11 pm
the guy before put 90w in the tranny i smell the oil and it was 90w that stuff has its own smell i think that he did it cause their was a noisy bearing and thats what ive been hearing doh! well i figured it out alright party bonus
PostPosted: Sun Nov 23, 2003 10:48 pm
well i can honestly say the guy that owned my luv before needs to have moron stamped on his forehead.....for starters..... instead of taking rear bumper off he cut it off with a torch but left the bracket on the frame.....number two the temkin bearing in the rear he replaced but didnt put grease on them when he out them in.......found that one out in the middle of a horse pasture in four wheel drive when it blew the bearing...and i could go on and on....some people just shouldn't be allowed to work on vehicles sorry all the last post mentioned previous owners and it just infuriates me :(
PostPosted: Sun Nov 23, 2003 11:12 pm
kinda makes me irratated too but i am newbie to stuff so i got to let it roll off my back cause i might do something like that also :oops: jus not that bad
PostPosted: Sun Nov 23, 2003 11:18 pm
yeah i cant say much i have been known to take shortcuts but nothing like that but oh well crap happens 8)
PostPosted: Sun Nov 23, 2003 11:25 pm
tru tru
i am goin to jus soup up my 4 banger i think instead of gas guzzlin v8 sorry but i am not ready for it yet like i said i would love to have 3 luvs one powered off of tap water one hot rod and my stock luv 4x4
PostPosted: Mon Nov 24, 2003 2:20 pm
that would be one hell of a truck if you ran it off of tap water.
Currently no more luv's... But in search of one!
PostPosted: Mon Nov 24, 2003 7:52 pm
yah i know it has been done before too all it does is breaks up h20 into hydrogen by sending electrical frequency pulses to it using a circuit and you would have to modify carb a little by a fuel cell use ceramic coated valves and exaust or stainless steel parts their is a lot to it and of course hydrogen is damned explosive so ever hear of h-bomb yah so you have to have gauges to watch psi of
it and a safty release valve, somehow it would have to work if you got in a wreck too thinkin bout that one funny tap water that would kill you :?
PostPosted: Mon Nov 24, 2003 8:09 pm
fixed my problem it was my tranny tha bearings are bad i put some lucas oil 7.00 a quart 8O i mixed it with some sae 30w and it does good mucho better
PostPosted: Mon Nov 24, 2003 9:22 pm
well if it works good then thats great
