It is currently Sat May 09, 2026 4:44 am
 Post subject: 1980 chevy luv dually?
PostPosted: Thu Jul 07, 2011 9:22 pm
thinkin bout puttin a dually rear end under my 1980 chevy luv mikado 2wd 4 speed 1.8l gasser. if any of the other members have done this and have pics and advice let me know, also should i use a toyota box truck rear end its the only 6 lug pattern dually axel i can think of, thanks guy much obliged
PostPosted: Fri Jul 08, 2011 2:01 am
JC Whitney used to have a kit to turn your axles into duely they may still have it check and see.
PostPosted: Fri Jul 08, 2011 6:41 am
I don't think the Toyota dually axles have the same 6-lug pattern, as I remember it is larger, something like the Isuzu box trucks.
PostPosted: Fri Jul 08, 2011 12:51 pm
The toyota Duallys are not the same lug pattern, they have a huge lug spacing and have specific wheels. but the Dually toyota axles are full float which is kinda nice for maintenance.
PostPosted: Fri Jul 08, 2011 7:40 pm
well guys ill look on jc whitney and see if i cant find any izusu but im also thinkin bout puttin a second axel and maybe extendin the frame a little to look like a transfer, what do yall think
PostPosted: Fri Jul 08, 2011 7:45 pm
also i was thinkin bout just addin a cheater axel in front of my axel with airbags but bein i dont have much money i could use a small air compressor but is there any other way to do that than just airbags? thanks guys
PostPosted: Fri Aug 05, 2011 3:26 pm
i think that would be cool!
As clear as a mud puddle!!
PostPosted: Tue Oct 11, 2011 5:08 pm
that would be adding quite a bit of weight behind that little 1.8 for daily driving 8O
but it would look epic! you could make it a little wrecker :lol:
PostPosted: Fri Oct 14, 2011 11:56 am
Jedi Pimp Master
My best guess is that the mini Dualies used stock deafened
And just had wheels with offset inside and out. I posted a pick
On here so
Where of a custom conversion done back in the day by some company it looked
Pretty cool
SRAD
My Wife is faster than you think you are
PostPosted: Sat Oct 15, 2011 12:38 pm
On here so
Pretty cool
SRAD
yeaa the "lil dooley" conversion? kinda cool lookin lol
viewtopic.php?f=12&t=25211&p=184726&hilit=lol+dooley#p184726
