It is currently Mon May 25, 2026 4:54 pm
PostPosted: Sun Sep 11, 2011 11:11 pm
i just picked up a 76 im the second owner it runs and drives motor runs strong its all original exept white spoke wheels i want to lower it and posibly do some performance to it but nothing drastic just a clean driver so i need some ideas????????????
PostPosted: Mon Sep 12, 2011 9:16 am
Jedi Pimp Master
Slam it! Spray the adjuster bolts
on the torsion bars with a bunch of penetrating oil
And let it soak for a few days. Lift the front off the ground
To unload the torsion bars then back the tension off
To lower the front. In the rear, pull the overload
Spring install a 1" or 2" lowering block. If you go
With a 1" block you can retain the stock U-bolts.
If you go with the 2" block you will have to use the
U-bolts in the kit, but here's where it gets tricky.
The U-bolts in the lowering kits are a little too wide
For the Luv rearend and have to be heated and rebent
To fit. Also the pins on the blocks are just a little too
Big around and have to be filed down some to fit. Take
A Look at my truck in the projects thread under
RatRod love, it is 1" block with overload spring removed
Rolling on 16"s that should give you and idea about
Wether you want 1" or 2". Also a cheap source for wheels
Late model 6 lug Chevy truck wheels are. Bolt on and
Can usually be scored cheap. Good luck oh and BTW. Post
Pics!
SRAD
My Wife is faster than you think you are
PostPosted: Mon Sep 12, 2011 10:39 am
Iv heard you get a better ride if u re index the torsion bars is this true and I wanna clear 18s
PostPosted: Mon Sep 12, 2011 11:00 am
Lol ur not gonna b able to clear 18s and get it as low as u want if ur talkin anything about having it as low as mine u better b cuttin fender to tuck an 18
PostPosted: Mon Sep 12, 2011 11:29 am
Really I don't wanna cut it at all unless I have to but I do really like the look of them on the ground I had a 74 that I had I let the torsions all the way out and had a four inch block in the rear but it road like a tank i had 15s on that one I was hoping I could squeak 18s under this one what size wheels and tires are u guys running?
PostPosted: Mon Sep 12, 2011 11:57 am
Jedi Pimp Master
205X50X16 and 215X60X16 the rear tires are a little taller than I wanted but the price was right
SRAD
PostPosted: Mon Sep 12, 2011 2:50 pm
The 50s don't rub on the front at all
PostPosted: Tue Sep 13, 2011 6:46 am
Jedi Pimp Master
At the most extreme turn possible the rim rubs the lower control arm, not the tire just
the rim. Haven't had any problems in the month that I've had this set up.
SRAD
PostPosted: Tue Sep 13, 2011 8:38 am
F*ck that make that b*tch tuck tire like all the cool kids mine does and its sickkkkkkkk put ur 14 s back on with fattys and slam that bitch!!!!
PostPosted: Tue Sep 13, 2011 9:25 am
A members former truck with stock Nissan Titan 18's...
viewtopic.php?f=4&t=12049&hilit=Titan&start=100
PostPosted: Tue Sep 13, 2011 10:52 am
I like the look of bigger wheels on the luv but I also like the tucked tire look to but I don't wanna have rubbing issues
PostPosted: Tue Sep 13, 2011 12:16 pm
Slam that bitch and have tucked tires then. .......big wheels are played out anyways i swear if u seen my truck n person u wouldnt even b debating this rite now i have no problem with rubbing issues i gotts check on exactly wat size tires are on my 14 s but i kno there a 75 series
PostPosted: Tue Sep 13, 2011 1:04 pm
My truck has white spoke 14s maybe I'll powdercoat them black an rock them let me know what ur tires are
PostPosted: Tue Sep 13, 2011 9:28 pm
Jedi Pimp Master
Look at stock. 6 lugs as some of the factory wheels can be had dirt cheap and look pretty good. And low, low is never enough till you digging a trench! I agree slam that truck!
SRAD
