It is currently Sun Jun 07, 2026 7:28 pm
PostPosted: Mon Aug 29, 2011 11:21 pm
:idea: Has anyone tried unicoils to get the correct angles of the smog hoses needed on a luv?
http://www.gates-unicoil.com/
90 degree elbow connectors arent working.
i have the 5/8 heater hose but it kinks?
What part is this?
What is it for?
How Do I test it?
Where do i get a new one?
Are we there yet??
PostPosted: Mon Aug 29, 2011 11:59 pm
I'm sure they would take out most of the kink, but the emission hoses make some pretty sharp turns. I was actually thinking about making all my emission lines hard lines, then putting the nice red/blue Steele hose covers on um.
PostPosted: Tue Aug 30, 2011 12:06 am
i read about cloth tape on it but the little l shaped one on mine is shot. has gash holes.
the littlest one is the one i have to fix- need it for smogging for sure.
What part is this?
What is it for?
How Do I test it?
Are we there yet??
PostPosted: Tue Aug 30, 2011 12:36 am
Hit up the local salvage yards in your area and hopefully you can find a luv that has these hoses, search these forums, there are a lot of ppl that take the smog off, maybe they still have some parts and pieces laying around.
PostPosted: Tue Aug 30, 2011 8:25 am
Sometimes your local parts store has a bin in the back with many misc. hoses in it. They might let you go dig through it to see if you can make one work for you.
PostPosted: Tue Aug 30, 2011 10:57 am
Jedi Pimp Master
I was just looking at air pump
hoses on mine as the inspection is coming up
I had considered making them out of 3/4"
Stainless steel tubing as I have most of what
I would need free at work. Just a thoughtful all needs these
Hoses?
SRAD
My Wife is faster than you think you are
PostPosted: Tue Aug 30, 2011 9:32 pm
This is what I've done in the past. You may need to trim off part of a hose to get what you want, or take two different hoses and couple them together. You get the idea.
PostPosted: Tue Aug 30, 2011 9:53 pm
thanks
What part is this?
What is it for?
How Do I test it?
Are we there yet??
PostPosted: Tue Aug 30, 2011 10:14 pm
Jedi Pimp Master
I was thinking a piecemof stainless the same size as the nipple the hose slips over bent to fit wold only need a small piece of rubber hose on each end and would last forever.
SRAD
PostPosted: Wed Aug 31, 2011 12:51 am
Hoses?
SRAD
I'll take a hard line set up for the emission hoses if you are going to attempt a "kit"...,
PostPosted: Wed Aug 31, 2011 1:12 am
Hoses?
SRAD
and what will be finished price ;) hmmmm
What part is this?
What is it for?
How Do I test it?
Are we there yet??
Users browsing this forum: Bing [Bot] and 50 guests
