It is currently Tue May 05, 2026 11:22 am
PostPosted: Sun Jul 31, 2011 9:39 pm
How much hp can you get out of these lil 1.8 motors and where are you guys finding all the components to rebuild your engines
PostPosted: Sun Jul 31, 2011 10:09 pm
weber carb from ebay 32/36 DGEV or 38mm outlaw $300-500
Header is the pace setter header 70-1105 i think is the mfct.# $150-200
electric fan. electric dizzy. one wire alt. straight pipe exhaust get nearly 180hp out of the 1.8l
but if you can find a g200 block and throw a g180 head on top it will give you higher compression and more tourqe
and the g200 is nearly the same weight as the g180.
find all you need on amazon and ebay.
ebay is good for new old stock.
hope this helps. have a good one!
1980 Chevy LUV 4x4 Weberfied Sold
1974 Chevy LUV 4x4 Weberfied
PostPosted: Mon Aug 01, 2011 5:48 am
Sweet thanks I will see what I can find thanks again
PostPosted: Thu Aug 04, 2011 5:20 pm
I have a 1979 4x4 And a 1980 4x4 how do I know which motor will be in them with out taking it out? Or are all the chevy luvs the 1.8?
PostPosted: Thu Aug 04, 2011 7:11 pm
They were all 1.8 I think. Up until 1981 at least. On the side of the block you'll see a G180 or if it has been swapped to the bigger bore block it will have G200.
PostPosted: Thu Aug 04, 2011 8:03 pm
Ok I will look I don't think they've ever been swapped but you never know thank you for the info
PostPosted: Tue Nov 01, 2011 2:04 pm
82 or 83 is when the 1.9L came out. it was the only gas engine tell 86 when the 2.3L came out.
86\87 the 1.9L is a 2WD only engine. not sold after that......
86\87 the 1.9L was only sold with a 4sp and 3.42 rear gear.
the other years 82\85 it was sold with a 5sp\3.73 or the 4sp\3.42 "in the 2WDs"
mixing the 3.42 with the 5sp you need smaller then stock tires :!:
the 1.9L is in the same engine family as the 1.8L thus many many things inter change.
86trooperT/D 2.2
84 L\B 4x4Diesel LS 2.2
86 L\B 4X4 gas 5 speed 2.3
PostPosted: Thu Nov 03, 2011 5:09 am
Just wondering With just the add ons you mentioned that doubled your HP? 180hp is alot.
PostPosted: Tue Mar 06, 2012 1:59 pm
also was wondering on that one? i would think it would be hard to hit the 100 mark without headwork
