It is currently Thu Mar 26, 2026 12:33 am
 Post subject: luv engine problems
PostPosted: Thu Oct 09, 2003 6:24 pm
Even though I am very new to this site, I've enjoyed reading all the posts and the wealth of information that has helped me alot. But at this time my son has a 1980 Luv 4x4 with an engine problem. We just picked it up a week ago used, of course. I had to put a started on it. It wouldn't start. I put the usual tune-up stuff on it (plugs, point, cap, etc.) and it started, but runs rough, won't idle, no power. I've played with the timing a little to no avail. The carburator is new, it has headers, but has a miss somewhere causing it to run rough. A friend came over and listened to it and said it could be something like a blown head gasket, loose rocker arms, etc. Any help would be deeply appreciated. By the way, it's a 1.8 liter. Thanks again.
A 1980 luv that chevy 4x4
PostPosted: Thu Oct 09, 2003 7:19 pm
theres a few other things you should check. Fuel filter may be plugged and i would adjust the valves too. To check if the head gasket is blown just get it running a little and see if it smokes white. Also you can pull the sparkplugs and if they have coolant on em then its gone.
PostPosted: Fri Oct 10, 2003 4:55 am
yeah what MEPR said....and if you have a compression tester that could help also.
03Cobra
PostPosted: Fri Oct 10, 2003 6:06 am
How long did your truck set before you bought it? If it set for a long period of time , your fuel could have water in it , or it could have turned to varnish. :( When my head gasket went bad , i didnt have any smoke...just a severe case of not much power...mine was blown between 2-3. That was about 3 years ago.
PostPosted: Fri Oct 10, 2003 6:33 am
thats the first time i've heard that. i thought all luvs blew between 3 and 4.
PostPosted: Fri Oct 10, 2003 11:17 am
sounds sort of similar to what mine was doing, after a couple of trail runs, it had no power, wouldnt even take off in 4low 1 gear. sounded like was running strong on 1 cylinder. smoke bad also, but not like it would with a blown head gasket. also had a tremendous amount of blow-by. upon teardown, we found the problem. i snapped 3 of the top piston rings, adn they chewed up the ring lands on my pistons. only 1 of the pistons was in decent shape. o well, im gettin it rebuilt, and it should be out of machining later this week.
PostPosted: Fri Oct 10, 2003 12:56 pm
i was going to say, no power+blowby=shot rings. But you found the problem so, good luck whith your rebuild.
PostPosted: Fri Oct 10, 2003 2:05 pm
The engine doesn't smoke at all. I'm not sure how long it set before I bought it. When my friend was over we went through the firing order to make sure it was OK. No crossed wires, etc. But the 3 and 4 cylinders act like they're not firing all the time. Could that be a valve adjustment? When I got it there was not rear drive shaft. It was in the bed along with a junk starter. I am in the process of finding either another drive shaft or an end so I can get this drive shaft put back. I can lock in the front hubs and put it in first and it will move but just starts running real rough. I really appreciate all of your help. What do you think with this added information?
Thanks a bunch. :?:
PostPosted: Fri Oct 10, 2003 3:23 pm
Ran a compression test on the truck. cylinders 1 and 2 were 120 pounds. cylinders 3 and 4 the gauge didn't move. But it usually starts right up, just a rough running, won't reach hardly any rpms. None of the plugs looked oil fouled. What do ya'll think? Blown head gasket or what?
Thanks again for helping me out.
PostPosted: Fri Oct 10, 2003 4:02 pm
Hey man,
Sounds like you need a rebuild or a new engine!
PostPosted: Fri Oct 10, 2003 4:31 pm
It could be a case of someone adjusted the valves way way too tight, but I'd lean toward headgasket. Might as well pull the valve cover and take a look, and then you're already part way there to pull the head as well.
It could be seriously bad rings, bent/burnt/broken valves, or damaged pistons, but head and head gasket problems are much more common. Only real way to find out is to pull the head and start looking.
PostPosted: Fri Oct 10, 2003 9:45 pm
check your valves. If they are good the n youll be better off rebuilding it than trying to find the problem.
 Post subject: thanks alot
PostPosted: Sat Oct 11, 2003 8:23 am
thanks alot for yall's help, ill check the head, and go from there. ill let you know what happens
 Post subject: Re: Engine Problems
PostPosted: Tue Oct 14, 2003 11:49 pm
Hey is one for all you Luv Nuts out there. Tonight after replacing my spark plug wires, I was coming home off the highway(go small towns go) and as soon as i turned a corner, I lost all my power(ie i press the gas pedal and it didn't rev or go)I still had power(ie elecical juice) when i stopped the truck on the curb, i did smell alot of gas in the air. Though here is alittle aobut my trucks history. I bought it from a guy who hauled jsut about everything on it(like boats) an really replaced well..nothing i guess..he sold it cause he had too many carsand blah blah blah. well, lets see. i took it off roading once( ok around in a dirt pit) and suddley i got blow back?(ie popping noises everytime i tried to go past 50). Well it hought i must be the muffler pipes(as the guy put a can soup? body around the flex plate or something like that). Also, He never cleaned/or replaced the spark plugs so i guess he may have done something with the carb to mix the gas/air ratio up higer so the plugs could catch easier. Now could someone tell me if i should spend more cash on it, or jsut sell it to the J-yard?
Thanks
PostPosted: Sun Nov 16, 2003 8:55 pm
i broke the vaccum line from the intake to the brake booster 1 time.lost power and idled liked crap.might check that being it only cost me $5
