It is currently Sat Dec 13, 2025 8:29 pm
Post new topic Reply to topic  [ 1122 posts ]  Go to page Previous  1 ... 31, 32, 33, 34, 35, 36, 37 ... 57  Next
 Post subject: Re: LUV II
PostPosted: Sun Jun 05, 2011 10:20 am
LSX LUV Owner
its the new style!
decided to get off my ass and get the bench mounted, and wrapped. also went and stripped some of the wiring i had for the bag shit, and extended a few wires that had to be extended to put my ignition and headlight switch in dash.. needa loom the wiring, and see about mounting my shifter. might be impossible with the trans in.
def. not the best wrap job, but the entire bench swap has cost me no money.. so itll do for now. especially since im putting an offer in on a house today. lol
PostPosted: Mon Jun 06, 2011 12:35 am
Nice, gonna do the door panels like that too?
and an off topic question, do those dollies work pretty well for moving it around? Been debating about getting some I can move mine around easier.
PostPosted: Mon Jun 06, 2011 12:24 pm
My buddy has a set of them from Harbor Frt. and they work well. He moves around a 16ft travel trailer on them all the time.
PostPosted: Tue Jun 07, 2011 8:35 am
I have them as well and it does make it a lot easier to move it where I want it since you can move any direction.
PostPosted: Tue Jun 07, 2011 1:54 pm
Thanks guys and sorry to hijack Wicked. 8) Will probably pick up a set next time I am in Montana, almost bought those go jack clones that HF sells but they seem way to bulky even though they would be easier to use.
PostPosted: Wed Jun 08, 2011 8:41 pm
LSX LUV Owner
id much rather have go jacks. they would be much quicker. my dad bought these yearsssssss ago. definately makes it nice when working on a vehicle. i can turn it sideways in garage, then push it right up against the wall when done.
PostPosted: Sun Jul 03, 2011 5:17 pm
LSX LUV Owner
Not much going on with this thing. Been busy buying my first home, and getting settled into it.. Dad had gotten a built aod, then decided to do a ls swap in his little car. so he sent the aod back and got a 4l60e. built to handle 600hp. So i should never have any troubles with it again lmao.
heres a few pics of the truck at its new home.
heres the only pic i got of the old mans car with the new motor mocked up..
PostPosted: Mon Jul 04, 2011 8:48 pm
LSX LUV Owner
hosed out the garage..
got trans out
swapped bellhousing to new trans
PostPosted: Wed Jul 20, 2011 8:59 pm
LSX LUV Owner
yeah i know how it works...
got the bed off
got the frame marked on where the new top of frame rail will be.. friday i need to get some 2x3 and 1x1..
PostPosted: Thu Jul 21, 2011 4:17 pm
You just couldnt stand that pristine garage without some kinda project going on could you? :P
PostPosted: Thu Jul 21, 2011 10:24 pm
LSX LUV Owner
had to make some kind of noise to test the neighbors tolerance.. so far so good.. *knocks on wood* :lol:
PostPosted: Fri Jul 22, 2011 12:57 pm
LSX LUV Owner
lunch break update
PostPosted: Fri Jul 22, 2011 6:42 pm
LSX LUV Owner
wiring shortened up, exhaust hanger stuff modified and moved around. just need to get a couple an fittings to finish the fuel system. finally got bed butchered up enough to get the main part out..
PostPosted: Fri Jul 22, 2011 7:48 pm
so why are you doing this again?...i must have missed it the first time
PostPosted: Fri Jul 22, 2011 8:26 pm
LSX LUV Owner
Took bags off. Want a deeper bed floor now. And old floor got warped by me welding it to much. And I like redoing things lol
PostPosted: Sat Jul 23, 2011 1:17 pm
plus its a mini truck.. no matter how much time and money you spend on it it wont be quite frinished... always that one next thing to make a lil better
PostPosted: Sun Jul 24, 2011 5:42 pm
LSX LUV Owner
PostPosted: Wed Aug 03, 2011 10:00 am
I just joined but have been following this build. FRICKIN' AWESOME! just a couple questions...........for now. Early in the build you started with a set of black painted pacesetter headers. what were they to fit? F-Body? How much did you notch the rear of the frame in to tuck the 10" wides. I just inherited my Grandfather's '76 Luv that I have always Luv'd. I am going to be doing the LSX swap and want to be able to tuck 10". Thanks for the help and awesome build. Keep it up brother.
PostPosted: Wed Aug 03, 2011 8:58 pm
Hey , if you don,t mind me askin where is your new place at ?
PostPosted: Thu Aug 04, 2011 2:44 pm
LSX LUV Owner
headers were for an 02 camaro. and i dont remember how much i had to notch. been a while lol. look back and i might have said in the thread somewhere.
Dickinson
