It is currently Fri Jul 03, 2026 7:48 pm
 Post subject: smog exhaust port plugs
PostPosted: Sun Jul 17, 2011 6:42 pm
does anyone know where to get plugs for the smog pump ports? or at least size and thread pattern, nobody has them nor knows how to get a plug that size around my area help would be greatly appreciated
1977 LUV weber 32/36 dgv soon to be boosted
PostPosted: Sun Jul 17, 2011 8:25 pm
If I remember correctly they are M14x1 thread found little elsewhere except spark plugs. Do a search. This is a frequent topic. I used Kwick Metal and some plugs that didn't quite fit.
PostPosted: Sun Jul 17, 2011 9:41 pm
Remove the rail by unscrewing the threaded fittings out of the head, cut each tube & slide the cut end out of the threaded end of the fitting. Tap the inside of each fitting for a bolt or plug that fits, screw the plug into the fitting, then screw the plugged fittings back into the head.
Use the same method to plug the EGR tube connector at each manifold if you want to remove it.
PostPosted: Mon Jul 18, 2011 6:36 pm
jus go to a parts store its only pipe thread ??????? cost me i believe 6 bucks for 4 plugs i believe there 3/8
PostPosted: Mon Jul 18, 2011 7:03 pm
That's exactly what I did to my '79.
2005 Silverado 3/4T Crew Cab
1981 Luv 2WD
1995 Roughneck JetBoat
1981 Luv parts trk
PostPosted: Mon Jul 18, 2011 7:56 pm
Pipe thread even isn't close.
PostPosted: Mon Jul 18, 2011 9:45 pm
Please reread previous posts and you will find that a pipe tap was involved.
PostPosted: Tue Jul 19, 2011 6:01 pm
I used oil drain plugs with the flange ground off.Of course they were the same thread and pitch as the ports!
Users browsing this forum: Baidu [Spider] and 29 guests
