It is currently Mon May 25, 2026 6:46 am
 Post subject: s10 rear end shortening
PostPosted: Mon Jun 27, 2011 12:08 pm
Question for you guys. Im going to get an s10 rear end for my luv, long term project that I have. I want to shorten the s10- rear end so that I can get a deeper rim look (Like deep 19x12's) on the rear end. I know there are custom modifications that have to be done to the bed and frame, but im not worried about that. Im not looking into upgrading into a V8. Im going to keep the 4 banger and just do modifications on that, therefore I dont need anything stronger than the s10 rear end. Im in the Ontario California area. What shop can I go to around here that would shorten the rear end? thanks for your help.
PostPosted: Mon Jun 27, 2011 1:02 pm
One of the main problems with narrowing a S10 7.5 rear axle is the axles are retainen by C-clips in the carrier . To narrow one you will need c -clip eliminaters or need to contact someone like moser and see what the cost of machining a factory axle is . You will end up spending close if not more than doing a 9 inch Ford imo .
PostPosted: Fri Jul 01, 2011 2:36 am
dude thats insane on prices 2 bad ya aint close mo ga i got a guy that will shorten the housing and build custom axles to fit....had mine shorten 2 1/2 in and new axles and it only cost me 300 bucks...of and you cant narrow stock s10 axles ne way cause they taper at the end..
Epic Fabrication.
KAOS
PostPosted: Fri Jul 01, 2011 9:11 am
Thanks for the input guys. Ill ask around here and see what I can do. Not in a hurry anyway. Working on it little by little, and I have lots to do.
PostPosted: Sat Jul 02, 2011 12:48 am
jus kno that if i rem right s10 diff is 1in wider than a luv rear...when i shortend mine it fit perfectly under the bed with regular s10 wheels....
Epic Fabrication.
KAOS
Users browsing this forum: Google [Bot] and 21 guests
