It is currently Mon Jun 08, 2026 1:10 pm
PostPosted: Thu Nov 13, 2003 9:01 pm
Im wanting to mount my amps on the back wall of the cab interior. Ive cut a piece of peg board ti fit because I thought mounting the amps to that would allow some air to circulate. If this will work, I would like to cover it with some sort of fabric that will hold up to the heat coming off the amps. My main concern of course is the heat. Will the peg board work? What choises do I have for covering it? Also thought about using diamond plate instead of the peg board. Any ideas?
PostPosted: Thu Nov 13, 2003 11:07 pm
what kind of power u runnin? my amp is sitting behind my seats of my 98 Sonoma, and im runnin 1200 watts, i have had no problem with heat buildup, it will get warm, but not past its thermo-protect shut off. (trust me, i push it really hard :twisted: ) also how heavy is the amp, my amp weighs around 5or 10 lbs, will the pegboard hold that w/ out flexin too much? also what kind of system u usin? u may be able to rig up a amp mount on the box or sumthin.
im hopin to mount at least 1 10" in my luv, with 375watts goin to it, but have to finish some other wireing frist.
jsut my 2 cents
PostPosted: Fri Nov 14, 2003 7:53 am
Ive got one amp for the sub(12")(350 w) and one for the seperates(120 w). Ive got the peg board screwed into the bracing along the cab back. I have the amps mounted on it now and its holding up fine. The amps are behind the passenger seat and the sub behind the drivers seat. I also thought about using some round tubing as a spacer between the amp and the board and running some long bolts through them to mount them up off the board. Ive never had amps in anything before, so I dont know how hot theyll get. Just read the warning in the manual about them getting hot.
PostPosted: Fri Nov 14, 2003 8:58 am
you should be okay if you keep a window cracked for ventilation. :)
 Post subject: 81 chevy luv diesel
PostPosted: Sun Nov 23, 2003 9:20 pm
I have 2 10inch subs in my truck behind the seat with a 1000 watt amp mounted under driver seat.....and seem to not have a problem with heat at all.....so thats a idea
PostPosted: Mon Nov 24, 2003 9:30 am
hey i like the idea of diamond plate aluminum its all shiny and stuff
aggressive ok when i buy a system all plasma some holes for speakers to sit in and mount amp and try your idea
PostPosted: Mon Nov 24, 2003 12:48 pm
I had a coustic 360 for the sub and a coustic 260 for the mids and highs when the truck was together. I didn't mount it to anything but the rear wall, because it had rises already in it. I never had any problems with heat.
03Cobra
PostPosted: Mon Nov 24, 2003 8:53 pm
You guys are lucky to have that much room. I have an '81 and I am going to have to figure a way for 6X9's to go behind the seat.
PostPosted: Mon Nov 24, 2003 9:03 pm
the luv i have is a 81 diesel and thats my next trick as well is to put six by nines in there as well should be interesting
PostPosted: Mon Nov 24, 2003 9:15 pm
Well slick, if you figure out something soon keep me posted on what you do. The only thing I have about half figured out will require me to remove the seat. I hate to do that just for 6X9's :lol: .
PostPosted: Mon Nov 24, 2003 9:19 pm
yeah that is my problem too have the two ten inch subs right now...so will be a tight fit gonna try and do that the weekend after thanksgiving so will post if i figure something
PostPosted: Mon Nov 24, 2003 9:26 pm
Cool, I will keep an eye out.
PostPosted: Wed Dec 03, 2003 9:43 pm
I had a box that was made for 2 6X9's. I cut it in half and there was a spot on both sides behind the seat that they would fit perfectly. And I can still slide the seat all the way back. 8) Now I just have to put the stereo in it. :lol:
PostPosted: Sat Dec 06, 2003 3:55 pm
That jusy might work will try it
PostPosted: Sun Dec 07, 2003 2:10 pm
Got my stereo installed today. It sounds really good to be just 2 6X9's. It must be that little bitty cab. A small amp in it and it would be even better. 8) :D
