It is currently Sun Feb 08, 2026 11:16 pm
PostPosted: Fri May 27, 2011 1:53 pm
My 1980 Luv is a California emmisions model (hose monster) so I'm eliminating as much of the smog junk as possible to clean it up under the hood and elsewhere. There are 3 lines that run to the fuel tank from the engine bay and several from the tank itself. I imagine that most are vapor recovery and other vent type hoses.
My question:
Which lines can I remove/plug, and which lines need to remain for normal (non smog device) opperation?
Thanks!
PostPosted: Sat May 28, 2011 8:41 pm
I just started my plans for putting a flatbed on my '81 LUV and am figuring out what to do with the lines under the cover in the bed of the truck. I can post what I come up with if you want. Anyone who has already done this....please jump in.
I desmogged everything under the hood of my '79 as far as pollution pump and rail. That's not to hard. I just removed everything and plugged the holes.
2005 Silverado 3/4T Crew Cab
1981 Luv 2WD
1995 Roughneck JetBoat
1981 Luv parts trk
PostPosted: Sat May 28, 2011 8:54 pm
Thanks, yes I desmogged the engine bay already, just wondering what to do with all the leftover spagetti
PostPosted: Sat May 28, 2011 9:22 pm
u should have a fuel return line off ur carb and thats it as for ur gas vent box n ur bed just role with it seen to many people vapor lock a motor taken them out
PostPosted: Tue Jun 21, 2011 8:40 am
Does your motor sound funny now that you plugged your cylinders? I also plugged my cylinders and now it sounds just like a weedeater lol. Anything I can do to fix it?
I Dont Need Sex Life Fucks Me Whenever It Can.
