It is currently Sun Dec 21, 2025 12:12 am
Post new topic Reply to topic  [ 49 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Wed May 06, 2009 6:15 pm
Hey, do you have to max out the tortion bars to get the trooper a-arms underneath it and get the suspension lift?
I have a 80' 4x4 that i wan't to get about a 3-5" lift out of, i know i can shackle up the back, get re arched springs, flip the axle, block it up or just about anything else, but i can't find out how to lift the front! And then when i read this i was so happy!
So a little info would help so much.
Also, if anyone knows where to fidn the front spindle lock washers, i would love that because i can't find them anywhere.
PostPosted: Thu May 14, 2009 10:27 pm
Ditto.
PostPosted: Sun May 31, 2009 12:09 am
I'm actually in the middle of this swap now, I'll let you know how it goes Jacob. Currently I am doing it without the ball joint spacers, just flipping the ball joint.
PostPosted: Tue Jun 02, 2009 5:28 pm
That would be so nice because i would really like to stay away from a SAS right now because it is what i usually drive everywhere, school, work, and i play with it. And this would just make my day.
The Luv Master :D
PostPosted: Tue Jun 02, 2009 5:55 pm
Australian LUV Guru
Fitting Trooper upper arms with a flipped b joint and spacer will give you more downward travel, useing a shorter bumpstop will also increase the travel. You will have to re index the torsion bar and wind it to get max lift. Remember that once you have done all above, your cv angles are now extreme and their lifespan will be shorter, the next step is to do a diff drop.
1980 4x4 KBD40 ISUZU/Chev Luv
PostPosted: Sat Jun 27, 2009 1:34 pm
For those of you that have put on the Trooper arm with the flipped ball joint (and maybe used shackels for the rear), how much of lift did you get?
PostPosted: Sat Jun 27, 2009 3:20 pm
I only got a few inches in the front, whereas in the back when I did a spring over I got about 8 inches. Im gonna need to crank the torsion bars a little, and maybe take out a spring in the rear.
PostPosted: Sat Feb 06, 2010 2:01 pm
so if im reading this correct, 84-86 trooper upper control arms will only work on the 4x4 luvs and not the 2wd?
If you ain't livin on the edge, your takin up to much space.
PostPosted: Sat Feb 06, 2010 7:25 pm
Australian LUV Guru
Trooper upper arms will work on a 2wd
PostPosted: Sat Feb 06, 2010 7:30 pm
ok just wanted to make sure thanks! how much more travel does it seem to gain?
PostPosted: Thu Mar 25, 2010 9:19 pm
3 inches at least. Likewise 3 inches of lift. Tore em off though, doing a SAS, so if anyone wants em, I've got em up for sale.
PostPosted: Mon May 31, 2010 11:57 am
so,
a short recap of the procedure
Find some trooper upper control arms
Also, find some ball joints from the same year trooper that the donor arms come from
when installing the ball joints, install from the underside of the control arm rather than from the top like normal
then put everything back together and get an alignment right?
PostPosted: Mon May 31, 2010 2:46 pm
Australian LUV Guru
Figuarus wrote:
so,
Correct. Be sure to use new high tensile bolts and locking nuts when installing b/joints.
PostPosted: Tue Oct 26, 2010 8:07 pm
anyone know if i can use upper control arms from a '87 pup on a '78 luv?
PostPosted: Tue Jun 14, 2011 8:29 pm
Okay so I'm confused do you have to crank the t bars to get the lift from this swap or does the arms itself lift it? I don't wanna crank the t bars much for the fact of a crappy ride I'd like to still have a descent ride
PostPosted: Wed Jun 15, 2011 1:18 am
Australian LUV Guru
Swapping out the arms alone will not give you lift, they will however give you more downward suspension travel. Combine this with a shorter bump stop you will get even more travel. You can crank the t bars for lift without sacrificing ride quality by reindexing your t bars.
PostPosted: Wed Jun 15, 2011 5:56 am
Call me stupid but I don't know what reindexing the t bars is I've never messed with em before
PostPosted: Wed Jun 15, 2011 6:04 am
And also can you put the lower control arm from a troops on a luv?
PostPosted: Wed Jun 15, 2011 6:12 am
Australian LUV Guru
You could but there is nothing to be gained
Re indexing is removing the t bar and rotating it in the splines ( there are some good write ups out there, Google is your friend)
PostPosted: Wed Jun 15, 2011 11:11 am
Okay thanks us 45 bucks an arm a good price?
