It is currently Fri Mar 20, 2026 7:30 pm
 Post subject: Trailer wheels
PostPosted: Sun Jun 12, 2011 1:11 pm
Is it possible to use trailer wheels on the LUV? I have found several nice wheels with the correct bolt pattern but im not sure if there's something Im not thinking about. Thanks
 Post subject: Re: Trailer wheels
PostPosted: Sun Jun 12, 2011 5:56 pm
As long as the center hole is the needed size and the lug pattern works, sure, why not?
PostPosted: Mon Jun 13, 2011 12:56 am
wheels from a trailer that fit a auto, yes thats just fine.
tires that are rated for trailer service NO, DO NOT USE TRAILER TIRES ON A AUTO :!:
where car tires have a P, or truck tires have LT, trailer tires have a ST stamp, at least the ones ive seen have.
86trooperT/D 2.2
84 L\B 4x4Diesel LS 2.2
86 L\B 4X4 gas 5 speed 2.3
PostPosted: Mon Jun 13, 2011 9:01 pm
Check the load rating on the wheels and generally no don't use trailer wheels on a auto But I have trailer wheels that are rated 2850 lbs. and i am going to run them on my LUV 4X4 but i sure as hell would not run them on a full size as they will break the centers out on hard turns. at least that is what i am told and will abide by that but a luv 4x4 is about 2900 lbs. so i will run them.
Oh I'm sure there will be a lot of ideas on this mater.
