It is currently Mon May 25, 2026 4:52 pm
 Post subject: screw in ball joints
PostPosted: Sat Jun 04, 2011 6:53 pm
hey does any one know where and maybe a part number on some s10 style screw in ball joint. i googles searched and all i found was like crysler for and dodge stuff.?
Epic Fabrication.
KAOS
 Post subject: Re: screw in ball joints
PostPosted: Thu Jun 09, 2011 10:18 am
There are none with the correct taper for the S10 Spindle.
Thus the reason i went with a machined plate.
HOWEVER. I do carry the correct taper chrysler bit if you would like to re-ream your spindles. I belive the K-72 from moog is what your thinking for the chrysler screw in.
A.j.
PostPosted: Thu Jun 09, 2011 7:15 pm
found some screw in style on mautofied but waiting to see if he has a part number on them so i can see what they are exactly he says they were bought for s10 spindles but theirs only a pic of em..how much does the taper run to re-ream the holes..gona rebuild the lwer joint to take a bushing in stead of a ball joint..any info into this is apprecieated..
Epic Fabrication.
KAOS
PostPosted: Fri Jun 10, 2011 5:34 pm
heres the part number on those ball joints (910-34323 ) their from speedway motors seys their for i believe 68-69 chrysler...should be almost the same as the moog k72..any herlp with a lil insite on the taper diff n a ruff guess to how much the right taper reamer will run me is a plus..thanx yall
Epic Fabrication.
KAOS
PostPosted: Fri Jun 10, 2011 8:51 pm
You can buy either a 7 degree taper reamer or a 10, they look the same be SURE to get the correct taper reamer! And you need the 7 degree one, I believe...
PostPosted: Sat Jun 11, 2011 2:25 am
a.j, mytmouse thanx for yalls help.. i was lost..,culdnt find any thing helpfull far as the ball joint info on google..
Epic Fabrication.
KAOS
PostPosted: Sat Jun 11, 2011 6:07 pm
That would be the K772, which is a Moog number but almost any aftermarket parts store sells a version of these balljoints. www.speedwaymotors.com sells the balljoints, the threaded sleeves and the reamers. The speedway version of that balljoint is the best one to get because it uses a floating boot.
Michael White
www.dallashotrodparts.com
PostPosted: Sun Jun 12, 2011 10:00 am
sweet imma go ahead n get them cant beat 40 bucks for 2 ball joint n collars for them..thanx yall for the help..now jus got a find a reamer to borrow..or find a cheap enuff one to buy..
Epic Fabrication.
KAOS
PostPosted: Mon Jun 13, 2011 3:58 pm
i would buy the reamer man, there like 40 bucks at best.
the reason I say this, is the depth of the ream can be a feel feel kind of deal.
i tried to ream using the factory specs but the ball wouldnt fit properly.
so ream a little, then real alittle more until the taper seats just right and cover 2/3s of the joint shank.
might be a wise idea to practise on a old set of S10 spindles before going for the full monty.
but 100% for Speedway motors.
There actually my supplier for most of my kit parts. just wish they offered production machining too!
A.j.
PostPosted: Tue Jun 14, 2011 12:01 am
sweet thanx got em they should be here in a couple of days comin from ny..now jus wish i culd find a c3 vette rear diff..
Epic Fabrication.
KAOS
PostPosted: Thu Jun 16, 2011 1:10 pm
The K772 does not fit the S-10 spindle. It also does not fit the Toyota spindle.
If your doing all that why not just go with a uniball. a 3/4" uniball with misalignment spacers for a 1/2" bolt will work great on an S-10 spindle.
By the way the S-10 spindle has the same offsets as a Luv spindle. By that I mean that the distance from the face of the spindle back to the upper balljoint hole and the lower balljoint hole is the same in relation to each other on both spindles. Both spindles have 1" of difference from the upper to the lower holes. This means that you can theoretically swap in S-10 spindles and not have camber problems. The thing you do have to do is swap the balljoints out.
Michael White
PostPosted: Thu Jun 16, 2011 1:14 pm
but if you ream the taper on the spindles they will fit? if not mistaken a 7 degree re-reamer will allow them to fit....but what is this uniball you speak of like a heim joint?
Epic Fabrication.
KAOS
PostPosted: Thu Jun 16, 2011 4:16 pm
yes the reamer will allow them to fit. Just go slow and keep checking.
A uniball is a spherical type ball joint. They come with an outer cup and misalignment spacers. do a google serach for this part number..
wssx16t or look on powerperformance.com and click on uniballs
Michael White
PostPosted: Fri Jun 17, 2011 12:47 pm
so they are basically heim joints with no shank on them..i was thinking bout using heim joints where they connect tothe spindle and run solid bushings at the other end of the arm but wasnt sure bout keeping them in the right place and having all the camber/toe/caster right. cause dont you need a tapered insert to hold it all together? the heim (uniball) in the spindle hole.
Epic Fabrication.
KAOS
PostPosted: Fri Jun 17, 2011 1:10 pm
i found the uniball ur talkin boutat a diff place but by no means are they cheap..heres the link to see
http://www.polyperformance.com/shop/Uniballs-p-202.html
or else i could use heim joint with a hi misalignment or deflection washer right..
Epic Fabrication.
KAOS
PostPosted: Fri Jun 17, 2011 7:25 pm
yes, try summit racing for a much better price on them. They sell the balls, the cups and the spacers.
Ive done the research because Im about to start offering them on all my control arms as an option.
There are basically 4 sizes that will work for trucks. The sizes are the hole in the center of the ball. they come in 1.5", 1", 3/4" and 5/8"
Understand they come in several other sizes but those are the most popular. You will have to use the misalignment spacers and they have to fit in the hole. so a 3/4" uniball with a spacer has a 1/2" bolt hole.
Michael White
PostPosted: Fri Jun 17, 2011 9:57 pm
so hows it fit in the taperd hole in the spindle? im lost on tht part..
Epic Fabrication.
KAOS
PostPosted: Wed Jun 22, 2011 3:55 am
it fits thru the smallest part of the tapered hole and the other end has a grooved adapter that sits in the large part of the hole.
Michael White
PostPosted: Wed Jun 22, 2011 3:11 pm
i cant find this piece ir talking bout..i see the ont that fits in the heim to keep the bolt from coming thru..but nothing for the ball joint sizer thing.....
Epic Fabrication.
KAOS
PostPosted: Sat Jun 25, 2011 5:25 pm
in stead of the sizer to fit in the spindle culdnt i ream it staight...n make it the same size from top to bttom?......
Epic Fabrication.
KAOS
