It is currently Sun Jun 07, 2026 11:32 pm
 Post subject: Transmission Question?
PostPosted: Mon May 23, 2011 11:27 pm
I have a 1980 4x4 luv and i was wondering if a transmission out of a 2wd will bolt on to my 4wd? are they the same ones?
PostPosted: Tue May 24, 2011 10:45 am
Yes & no, not sure what you're asking.
A 2wd tranny will bolt to the engine and probably to the crossmember, but it will be 2wd only.
The 4wd trannies had a different back case half to include a t-case & may be longer than the 2wd.
PostPosted: Tue May 24, 2011 1:13 pm
can you bolt the t-case to the back of the 2wd tranny? because on my tranny out of my 4wd the t-case is just bolted to the back of the tranny
PostPosted: Tue May 24, 2011 3:49 pm
No.
PostPosted: Tue May 24, 2011 9:24 pm
And I think the drive shaft won't match up. You would need a 2wd shaft, or have one made.
PostPosted: Thu Jun 02, 2011 1:26 pm
if your wanting to up-grade to a O\D trans in your 4wd gen1 LUV you have two ways of doing it with the stock engine.
a 4wd MSG 5sp sold in 86/87 ONLY
its a clone of the 4sp MSG in your 1980 LUV, with a 5"ish expansion housing for the added 5th gear.
just 1st, 2nd , 3rd are a little taller
1st in the 4sp its like 4.1 to 1.
1st in the 5sp is 3.8 to 1,
5th is a 14.5% O\D. T-case gearing is the same 1979 to 1987.
2nd way....
a MUA from a 2.6L engine sold 88/91 in troopers. one from a 2.8L V-6 trop will work, but the housing and input shaft must be changed to the type used on a 2.6L engine.
there are other years in rodeos, amigos and trucks, but i don't know what they are.
there a bigger trans and will be a tight fit possibly needing body lift.
and there HYD clutch, the O\D is about 20%
"if" you have a 2.2L diesel the MUA idea will not work since no diesel housings for that trans are in the USA
86trooperT/D 2.2
84 L\B 4x4Diesel LS 2.2
86 L\B 4X4 gas 5 speed 2.3
Users browsing this forum: Baidu [Spider] and 49 guests
