It is currently Fri Jul 03, 2026 2:33 am
 Post subject: 4x4 to 2wd swap question
PostPosted: Fri May 20, 2011 8:20 pm
Alright I bought another 1980 4x4 LUV but it doesn't have a motor, trans, or front axle. It still has the hubs and everything else.
Now the question I have is would it be ok to drop an Lt1 in it with the front end missing the axle? Or would I need to get a set of 2wd spindles?
If I can just drop in the Lt1 and call it good that would be great otherwise I'll have to make a run to the junkyard. Any info would be helpful.
Also I already have an extra motor, trans, and I can get an axle but I would rather make it 2wd. Then I'll just sell the other stuff.
PostPosted: Sat May 21, 2011 1:12 am
Australian LUV Guru
Just plug up the back of the 4wd hub, with a old cv(minus shaft) to keep the grease in and crud out and all will be fine. I have a parts rig that was driven that way for many years.
1980 4x4 KBD40 ISUZU/Chev Luv
PostPosted: Sat May 21, 2011 9:28 am
Alright thanks that makes things a lot easier.
